Question about Lucas POWER STEERING FLUID W/COND.
Power steering is squeeking
How do i find the power steering
  • 4 Answers
Open the hood, and look on the firewall directly in front of the steering wheel. you should see a large (apox. 10-12" dia.) round, vert. mounted pan- this is the slave cyl.-mounted on the front of this is the master cyl. for the brake system. this is where you check the brake fluid level.
Posted on Jun 13, 2013
Steering wheel squeeks when turning either direction.
A squeak or a whining noise? If it is a squeak then it is something mechanical from your steering column down. Could be anything from rack and pinion to the tie rods and ball joints. If it is a whining noise the you need to check your power steering fluid and power steering pump. If the fluid is low then you have a leak in the power steering system somewhere and needs to be fixed before you ruin the pump.
May 17, 2016 | Cars & Trucks
Power steering
Have you inspected the belt? It is probably stretched or damaged...the belt turns the power steering unit, and charges your battery via the alternator...(low battery light) Did you drive through some deep water last night? Be sure to inspect this so you do not get stranded. Hope this helps.
Mar 24, 2014 | 2000 Oldsmobile Silhouette
Steering column squeeks when we turn the steering wheel. It makes me think the power steering is not working. But I believe the steering column needs a bearing replaced just under the steering wheel....
My parents have the same problem, its something to do with the steering colum itself, not with the power steering unit.
It is quite annoying though..
Mar 03, 2011 | 2000 Toyota Camry
My ford explorer 2004 4wd squeeks when i accelerate, i installed a brand new serpentine and a drive belt idler pulley and the squeeking noise continues. How can this be fixed?
Could be the bearings in the alternator, power steering pump, or a/c compressor. Try spraying penetraing oil in between the pulley and the alternator, power steering pump, and compressor one by one. If the squeaking stops. Replace that part.
Feb 06, 2011 | 2004 Ford Explorer
No Power Stearing, fluid is good, belts are fine. Small squeeking from pulley area.
Your power steering pump has probably failed and that is what the squeeking sound is. The power steering pump probably needs to be replaced.
Dec 28, 2010 | 2003 Lincoln LS
Squeeks and creeks from the front right wheel on my honda civic
you could have 2 problems. steering leak and poss a bearing. jack up the car and spin the right front wheel, makes noise there is a problem. if the noise only happens when you turn, with tire off turn the wheel and watch.
Mar 06, 2010 | 1997 Honda Civic
Car steering wheel sqeeks when I turn it. also,
Check the power steering fluid if enough, or replace your power steering pump
My power steering on a 2003 dodge stratus squeeks in the morning and is hard to steer. After awhle, it is normal.
Probably low level in the power steering fluid tank. If the level gets low again, it could be a leak(in my case was the hose underneath the tank.
Oct 20, 2009 | Dodge Stratus Cars & Trucks
Where do I pour the power Steering Fluid?
Pull up on the engine cover. It should pop off with slight force. The power steering fluid reservoir is under it.
May 27, 2009 | 2003 Cadillac CTS
Lucas POWER STEERING FLUID W/COND. Logo
27 people viewed this question
Top Lucas Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Lucas Health and Beauty Expert? Answer questions, earn points and help others
