Question about HP LaserJet 3030 All-In-One Printer
My hp3030 does not recognize the printer cartridge.
I've installed a brand new cartridge to replace existing cartridge (which is still good as well) but am getting an error message saying that there is no cartridge in place. help! thanks
  • 628 Answers
Those cartridges have a little chip that tells the printer that it's there. Check the contacts on the cartridge. If the old one is still recognized and the new one is not, then return the new one and get it exchanged.
Posted on Feb 07, 2009
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
I have a two year old printer not recognizing the cartridge. The print keeps saying "INSTALL BLACK CARTRIDGE". I bought a brand new cartridge and it is not recognizing it. What should I do
You arn't clear whether this message appeared with the old toner cartridge or just with the new cartridge.
If this message just appeared with the new cartridge and not the old one, take it back and get a replacement cartridge.
If the message also appeared with the old cartridge, the printer has a problem with the drum ground connector on the high voltage power supply.
Mar 02, 2011 | HP LaserJet P3005 Printer
Print program does not recognize existence of print cartridge in my X1150. I've tried 3 different new cartridges. It was working fine until the last cartridge ran out.
Some printers will not recognise generic brand cartridges. They seem to have a secret pin configuration that is different. maybe this is your problem.
Mar 20, 2010 | Lexmark X1150 All-In-One InkJet Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Why is my hp3030 printing light, enev with the
The Print head is dirty.Use the windows utlity or the hp utlity ro clean the head.
Good Luck
Nov 19, 2009 | HP LaserJet Q2612A Printer
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge...
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Sep 26, 2009 | HP DeskJet F380 All-In-One Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Jan 20, 2009 | HP LaserJet P3005n Printer
My lexmark printer x3350 send a messge that right side cartridge is not in right but it is can you help marion goforth at mlgoforth@hotmail.com
The first thing would be to remove it and reinsert the cartridge.
If it continues to not recognize it, try inserting a different brand new cartridge. If that cartridge is also not recognized, the connection between the cartridge and the printer is not happening. Typically printers do not cost enough to justify the expense involved in having a technician repair the unit. In other words, if you try installing two brand new cartridges and they both fail - it is the printer side of the connection that is bad.
Good luck.
Jul 25, 2008 | Office Equipment & Supplies
HP LaserJet 3030 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
