Question about Clothing Accessories
I'm looking for a truck looking buckle for my dad's belt, he is a truck driver
  • 7,365 Answers
  • 29 Answers
Check out these 2 websites:
http://www.bucklesofestes.com/trucking.htm
http://www.buckleshop.com/trucking_belt_buckles.htm
Posted on Jan 10, 2013
Seat belt alarm goes off intermittently when driving and buckled up. When I plug the passengers belt into driver,s buckle alarm is silenced. How can I fix this
There is a problem with the buckle sensor, it a really just a ground, circuit, try cleaning the buckle and belt end with spray brake clean, do not get it on the fabric of belt or seat covers.
May 11, 2016 | 2008 Ford Mondeo 2.0
2008 Ford Escape driver seat belt won't latch
replace the buckle
source from a wrecker /might be able to buy new not sure
Apr 29, 2016 | 2008 Ford Escape
Seat belt sensor goes on and off as your driving with all seat belts on
Look for garbage in the drivers seat buckle.
Make sure there is no heavy weight in the passenger seat.
You likely need a seat buckle, but could be wiring.
Dec 29, 2014 | 2008 Chevrolet Uplander
Air bag light flashes 5 times then 1 time
That flashing indicates fault code 51. Fault code 51 indicates a problem with the driver's seat belt circuit. The seat belt buckle has a switch in it to determine if the belt is buckled up when the seat is occupied [determined by a pressure sensor in the seat bottom]. The switch in the buckle is either bad or the wiring to the switch is either short or open circuited.
Use of a computer scan tool can help narrow down the problem. There are four different scan tool fault codes relating to code 51. They are B2432, B2433, B2434 & B2435. These codes will give you more defined information on the actual fault. Most common faults are either a bad switch in the seat belt buckle or damaged wiring to that switch. Damaged wiring is usually caused by the driver placing objects under the driver's seat, which damage the wiring coming out of the seat belt. It is also possible to have a bad seat belt computer [Restraints Control Module or RCM]. A bad RCM is not common. Check for damage to the seat belt wiring under the driver's seat. Best to remove the seat and lift up the carpeting to do this. If no physical damage or water corrosion damage is present, replace the seat belt. After repairs, disconnect the battery for 1 minute to clear the fault code from the RCM's memory.
Aug 27, 2014 | 2003 Ford Crown Victoria
Broken seat belt buckle
If I had the problem I would look at a junkyard or on line at e-bay for a replacement. You will need to get the buckle and the belt that it is attached to that goes down to the floor down through the crack in the seat.
Remember the buckle receiver is made for the certain belt in the front and rear seats. I have often tried to put the wrong belt in a buckle and it would not fit. ( Example: the right belt goes in the right buckle.)
Be blessed.
Nov 08, 2013 | 2002 Nissan Xterra
Changing a seat belt buckle
The buckles are placed on the belts and then they are sewn so that you cannot remove the buckles.. You will have to replace belt and buckle as a unit. murf427
Aug 03, 2012 | 1998 Oldsmobile Intrigue
Seat belt won't retract complete, drivers side
have a look to see if its coiled in twisted as you pull the belt out if the buckle doesn't line straight to the female end well its probely retracted in twisted to repair pull the belt out all the way and then realign the belt its quite hard to do so take your time hope this helps.
Jun 03, 2011 | 1998 Saab 900
2003 VW airbag warning light stays on. also will this keep me from getting an emission test in colorado? elvnmile@hotmail.com
DRIVERS SEAT BELT BUCKLE HAS A BROKEN WIRE AT THE BUCKLE, BEND THE BUCKLE AND LOOK VERY CLOSE, JUST AS THE WIRES GO INTO THE BUCKLE. ABOUT A $130 ITEM PLUS THE WORK TO PUT IT N.
Sep 12, 2010 | 2003 Volkswagen New Beetle Convertible
Driver side seat belt buckle is shorted 2004 VW beetle.looking for info on repair/replace
my seat belt/airbag light on...daeler told me I need a new drivers side buckle...approx 370 to repair!!!! light was on before they repaired, recall i guess, then 2 weeks later this happend
Feb 03, 2010 | 2004 Volkswagen Beetle
Clothing Accessories Logo
660 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
