Question about Vacuums
MIELE UPRIGHT VACUUM SHOWING A RED LIGHT ON THE ON LED
  • Vacuums Master
  • 18,392 Answers
Check for blockages, this link is for manual
http://www.totalvac.com/manuals/miele-vacuum-S7000-manual.pdf
Posted on Jan 10, 2013
advacak
  • 125 Answers
SOURCE: miele vacuum - red light
replace all your filters
Posted on Dec 06, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
miket756
  • 2702 Answers
SOURCE: Hi. Miele 5310 motor appears to have burnt out.
have a look at the switch first they can get worn but if thats not it look at the motor brush's if you have power to the motor but no "get up and go" no broom broom like! buy a new hover as a motor will cost you both arm's and one leg!!! plus its still needs to be fitted
hope this helps you? mike.t
Posted on Oct 20, 2009
  • 78 Answers
SOURCE: Miele s251i vacuum plus-red light indicator is on.
you will need to take the unit apart find the screws that hold the unit together 2 under the the bin cover at the hinges 1 holding the black control cover when you have removed the screw then just lift the cover it will be stiff just pull it up under this find all the screws and remove them remove the motor and you will see the pcb on the side of the motor it will have a dry joint on the solder this back up and that should do it make sure you unplug the unit b4 you work on it
Posted on Oct 30, 2009
SOURCE: I have a Miele turbo plus solaris and the red warn...
I had this problem with a different model. It's caused by a thermal cutout switch in the motor. My problem was a result of a filter being removed and the bag not seated correctly, hence dirt got into the motor and clogged the turbine, reducing airflow through the motor and causing the over heating.
If your motor runs at all, you probably have a blockage. Replace the filter inside the bag compartment just before the motor vent. Check the hose isn't blocked. Check the exit air filter.
If your turbine is clogged, it's a big disassembly job best done by a professional. If you really want to know how to cure it and feel you can tackle it yourself, email me. alan_at_alanjohnston_dot_com.
If your motor doesn't run at all and the light just quietly comes on, you have a break somewhere in the thermal protection circuit, either in the wiring (unlikely) or inside the circuitry buried inside the motor itself. I had an open on the thermal switch where the combination of heat and vibration deoldered the thermal switch from its board.
Hope this helps.
Alan
Posted on Aug 06, 2010
The hose is blocked, how do I get it off to unblock?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the hose to start unblocking it, do the following:
1. Put the vacuum in the upright position
2. Press the release button of the telescopic wand and remove the handle from the hose
3. Push the hose elbow downward into the catch hooks.
4. Undo the suction hose by twisting it at the elbow.
If the blockage isn't in this location you can do the following to search further for blockages:
5. Open the service flap on the back of the vacuum.
6. Unscrew the screws and pull the cover free.
Below I have attached a link to the users manual for the Miele S7210. You should refer to page 30 to view the diagrams pertaining to my suggestions.
http://www.sylvane.com/media/documents/products/miele-s7210-twist-upright-vacuum-users-manual.pdf
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Oct 14, 2015 | Miele S7210 Bagged Upright Vacuum
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
My Miele upright vacuum will not start. The red light will come on but not the motor. Why is that?
I believe you should have an amber light, if you are seeing a red light located above the bag compartment door, that indicates a fault with either the electronic module or the motor. Unless you have a voltage meter and are familiar with pulling plastic tabbed appliances apart, I suggest you email http://www.mieleusa.com/emailtomiele/emailus.asp?nav=&snav=&tnav=&oT=66 or call direct. Residential Appliances or Vacuum Cleaners(800) 843-7231Monday-Friday:8:30 am - 5:00 pm ESTSaturday-Sunday:Closed
Mar 04, 2013 | Miele S7210 Bagged Upright Vacuum
Miele S7210 red light on
You may have more dog hair in the main hose. Pull the hose out of the body, turn the lower hose swivel 90 degrees parallel to the floor and twist the hose off. You will see where to remove it at the swivel. Also check the port door on the back of the vacuum near the bottom of the upper section. It can be looks like a parallelogram with 2 plastic screws, twist the screws half a rotation and gently pry the cover off. After clearing out any debris, replace the cover and fasten the screws. A small LED flashlight will be very handy for checking all of the ports and hoses.
Feb 07, 2013 | Miele S7210 Bagged Upright Vacuum
Hose was not sucking but the rest of the vacuum seemed to be working. the model is a S7210 twist. it felt very hot and the red light was on. it then shut down completely. we can't see any...
No suction at the hose?
There could be a clog IN the hose somewhere. If it is easily removed, take it outside and run a garden hose through it. Your bag might be filled to the top as well...?
Jun 09, 2011 | Miele S7210 Bagged Upright Vacuum
My S 7000 upright vacuum red carp light on
its probobly the belt is broken
Sep 08, 2009 | Miele Vacuums
Mine is a new upright Meile power plus. When I have it
Sounds like you have a clog. There are screws in the back of the vacuum that you can undo and find the clog. If you need assistance or if that doesn't solve the problem.
http://miele.com/locator/locator_new.asp?nav=800&snav=800&tnav=800&oT=7
^this will help you find an authorized Miele repairshop.. you can also call them at (888) 785-2828
Aug 31, 2009 | Miele Powerhouse Plus Bagged Upright...
Vacuums Logo
466 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
