Magnavox dv200mw8 dvd/vhs combo shuts down right after turned on
My hubby bought a magnavox dv200mw8 dvd/vhs combo about a year ago and it will not stay on long enough to do anything. I will turn it on, the vhs part will try to eject a tape that is not in it and it will shut down. The same thing if I try to change it to dvd. Any suggestions besides taking a hammer to it? I have no patients.
  • millerpc Apr 11, 2009
    I bought a magnavox dv200mw8 dvd/vhs combo less than a year ago and it will not stay on long enough to do anything. I will turn it on, the vhs part will try to eject a tape that is not in it and it will shut down.
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Posted on Mar 02, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
I need A DirecTV Remote Code for the Magnavox DV200MW8 DVD Player VCR Combo
Magnavox is the problem. You won't find a code for that :( 10 years of trying and experience!
Feb 23, 2014 | Magnavox DV200MW8 DVD Player VCR Combo
I'm just looking for a owners manual for a magnavox vcr/dvd combo, modal number DV200MW8
Paste this into your browser and hit enter:
http://www.google.com/url?sa=t&source=web&cd=6&ved=0CEIQFjAF&url=http%3A%2F%2Fwww.funaiservice.com%2Fmanual%2FMAGNAVOX%2FManual%2FDV200MW8.pdf&rct=j&q=DV200MW8%20manual&ei=by8YTsPGHaLw0gGa7PSWBQ&usg=AFQjCNHuHrBspttvd3t1cfi3r6bohVnJmA&cad=rja
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 09, 2011 | Video Game Consoles & Games
I just bought a magnavox DV225MG9 A player . The salesman said it could copy vhs tapes to dvd. how do I do this with this machine?
If this is the correct model number, magnavox DV225MG9, above, this unit is only a DVD player not a DVD recorder. It won't dub DVDs to VHS either.
I wish that I could be more help.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
I have a magnavox dvd vcr combo mwd2205 The dvd
No solution just the exact same problem:
Does anyone know how to fix the DVD motor? I bought this from Walmart a few years ago and after about 1-2 yrs that was the 1st thing that went on it. The VHS still plays fine. I got tired of trying to "clean" it and its been packed away for at least 2 yrs. I recenly dug it out of the closet but of course its out of warranty. Is it worth repairing (its virtually brand new) or just get something else? Thanks for any suggestions in advance.
Nov 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can the Magnavox Dvd player/VCP DV200MW8 record shows onto VHS's
unfortunately the machine is not a recording machine IE: it is a player only. However in todays day and age you can pick up a good used one at the goodwill for around 10-20 bucks that can record. hook up is easy, one cable in one out and presto you can record on a blank tape. just remember the begining of a blank tape always has a few seconds of nothing on it so dont hit rec just as you are watching it start the machine about ten seconds early.
hope this was helpfull.
Dec 27, 2008 | Philips Magnavox DVD/VCR Dual Player
Model Magnavox DV200MW8 DVD/VCR Combo
try www.videohelp.com then type in dvd hacks there are various sites to go through.you can use search engines to your advantage.
good day
kz
Feb 20, 2008 | Philips Magnavox 20MC4304 20 in....
Adding a combo DVD/VCR player to my remote
you can find all the codes in this web site .. http://www.remote-codes.com/ please rate me if this work !
Jun 16, 2007 | Jensen JER-422 Universal Remote Control
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
