Question about Samsung ML Office Equipment & Supplies
Location of Solenoid samsung ML-2510 printer
Sticky solenoid. Paper feeds in fine 1 at a time. Any more and 2nd sheet feeds in half-way, after the 1st prints; stops & causes a paper jam
  • Philp Newyon Jan 10, 2013
    From different responses I have seen, it does appear the problem is a sticky solenoid. (Or the foam peeling off around it). Is it possible to access / clean this solenoid ( & gear wheel), from the back panel opening .... or does the circuit board & side panel also need to come off? ),
Pick-up SOLENOID needs replacing.
See this link.
http://www.arbikas.com/view/locator/ML-2510.pdf
Part is JC33-00015B SOLENOID-MP_R2;-,SCX-4720F,DC24V
Fairly involved strip down but there are a Cpl of you tube videos out there showing something similar.
Looking to undertake this task myself and will You Tube it.
Posted on Jul 25, 2016
3 Suggested Answers
SOURCE: HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Posted on Mar 17, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Samsung ML-2510 Printer. Picks up multiple sheets of paper most of the time.
I know this is an old post, but I thought I'd add this bit of info. I just fixed my ML-2010 by first replacing a torn pickup tire, but it still kept picking up multiple pages. I read a different post where the person traced it to a bad solenoid that was sticking in the open position as he described it. He replaced the solenoid, but on mine the solenoid was working, but I found it was sticking when closed. It is supposed to close and open once at the start of each page. Mine would close and stay closed sometimes until the start of the next page which would, of course, cause another pulse to energize the solenoid. I found it was due to a deteriorated thin half moon-shaped foam pad on the top of the solenoid's electromagnet that would cause the part that gets pulled in to stick to it for a couple of seconds before the spring would overcome the pad's stickiness and release it. I replaced the foam pad with a then piece of sticky-back felt that I cut to fit. When I reassembled it, it worked perfectly.
The way to get to the solenoid is to pull the covers, take the power supply boards off the back(as one unit, attached to a metal baseplate) and remove the panel underneath it, noting the screws and connections along the way. On the side where the solenoid is attached, I also saw a "split" gear that appeared to have a mark showing how they matched together, so be sure to realign the marks if they become separated before reassembly. Beyond that, it was a simple inexpensive repair. As these machines age, I would bet this is a major cause of this issue.
Feb 24, 2013 | Samsung ML-2510 Laser Printer
My samsung ml-1430 won't feed paper
There is a solenoid on the board of your printer. It pulls in the metal tab that allows that pickup roller to spin. It is supposed to let the roller roll once, but if it gets dirty, it gets sticky,and this might be the problem you are facing.
Here is the solution to the problem;
Take the board off of your printer and push in the tab. If it sticks for any longer than 1/4 of a second, then get a small flat-head screwdriver and remove the foam padding on the solenoid. Make sure you get it all. After that, get a piece of paper, fold it in half, and smash it in between the solenoid and the tab. Then slowly remove the paper, while still holding the tab. Do this until all the sticky stuff comes off on the paper. This should fix the stickiness, and allow the tab to go back out.
Thanks and take care.
Jun 29, 2010 | Samsung ML 1430 Laser Printer
Paper come out wrinkled and rippled.Looks like an unfolded fan
There seems to be a sticky object on the paper feed path, make sure there are no object in the path. Drum may be be getting too hot
Mar 06, 2010 | Samsung ML-2510 Laser Printer
Samsung ML2010 paper feed
clean the rubber pickup with water or alcohol by cotton cloth and try again
Feb 26, 2009 | Samsung ML 2010 Laser Printer
Problem with paper feed
clean the big roller with turps.
Dec 21, 2008 | Samsung ML-2510 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
SIMPLY UNINSTALL THIS PRINTER FROM COMPUTER AND REINSTALL IT AS A NEW PRINTER FROM THE INSTALL DISC THIS WILL USUALLY
FIX THIS TYPE OF PROBLEM
Jan 17, 2008 | Samsung ML-2510 Laser Printer
167 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
