Question about SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
Will not reconize250gb exterior harddrive - SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
2002 Mountaineer. How do you change the light bulb at the bottom of the driver side rear view mirror. Dan
SECTION 501-09: Rear View Mirrors 2002 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Dec 26, 2009 | 2002 Mercury Mountaineer
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Mirror glass replacement on drivers side
i don't have aviator. here's explorer, should be the same.
You will see a small rectangle where the screwdriver goes in. You are pryingtowards glass. The retention is about a 3 inch rectangle that has a lip around it that snaps onto a rectangle on the mirror body.
All mirrors
    1. Push the screwdriver into the notch until the glass is released. (and pull screwdriver towards glass)
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
Apr 18, 2009 | 2003 Lincoln Aviator
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
All mirrors
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
Apr 12, 2009 | 1999 Ford Explorer
My side mirros dont work
The exterior mirrors:
  • are controlled by power controls on the LH front door trim panel.
  • are of a foldaway design.
  • may contain turn signal indicators.
  • may be heated when the heated back window glass is activated.
  • may have a programmable recall memory option.
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
Power Exterior Mirror Operation
The power exterior mirrors are controlled by the DSM and are operational all the time, whether the ignition switch is on or off. Using the power exterior mirror switch, the driver can adjust the driver and passenger exterior mirrors four ways.
Visual Inspection Chart Mechanical Electrical
  • Exterior mirror(s)
  • Interior mirror
  • Central junction box (CJB) fuse
  • Circuitry
  • Exterior mirror control switch
  • Exterior mirror motor
  • Interior mirror
  • Driver seat module (DSM)
  • Memory set switch
  1. If the vehicle is equipped with memory exterior mirrors and the concern remains after the inspection, connect the diagnostic tool to the data link connector (DLC) located beneath the instrument panel. Select the vehicle to be tested from the diagnostic tool menu.
    • Check to make sure the program card is correctly installed.
    • Check the connections to the vehicle.
    • Check the ignition switch position.
  • The mirrors are inoperative
  • Circuitry.
  • Central junction box (CJB) fuse.
  • Exterior mirror control switch.
Apr 07, 2009 | 2003 Lincoln Navigator
2006 ford focus driver side mirror (electric)
Not that hard on this model.Here is a pic of the mirror and the removal and installation proceedure.
http://i253.photobucket.com/albums/hh43/chuck943/N0025797.gif
  1. Remove the exterior mirror trim cover.
    1. Release the retaining clip.
    1. Disconnect the exterior mirror control switch electrical connector.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror bolt.
    • To install, tighten to 11 Nm (8 lb-ft).
  1. If equipped, remove the exterior mirror screw.
    • To install, tighten to 2 Nm (18 lb-in).
  1. Remove the exterior mirror.
  1. To install, reverse the removal procedure.
Mar 02, 2009 | 2001 Ford Focus
Replacement of Mirror/Assembly, 2004 Ford E350 Super Duty
Exterior Mirror Removal and Installation
NOTE: Aero mirror shown, dual arm similar.
Manual mirrors
  1. Remove the mirror sail cover to gain access to the exterior mirror retaining nuts.
Power exterior mirrors
  1. If equipped, remove the front door speaker.
  1. Remove the front door watershield.
All exterior mirrors
  1. Remove the rubber plugs and dust shield.
  1. Disconnect the electrical connector(s).
    1. Disconnect the power exterior mirror electrical connector.
    1. If equipped, disconnect the heated exterior mirror connector.
  1. Remove the nuts and remove the exterior mirror.
Jan 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Wan't boot up
If the dvr isnt booting the harddrive, then the harddrive isnt seated properly in the removeable harddrive drawer, or the harddrive is improperly formated, or you have the wrong type of harddrive, or the master/slave settings on the harddrive are not set properly (master). what ive found is an 80gig/160gig is the most that these things will handle. and some brands work and some brands don't. and the harddrives have to be IDE/EIDE type drives. but it sounds like a harddrive interface problem. They like the older harddrive formatts/(not xp/vista)....good luck!!!!
Oct 27, 2007 | Samsung SSC DVR Digital Video Recorder...
SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow Logo
26 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
