Question about Acer Aspire One PC Notebook
Will a aspire 5610 work with battery out?
Aspire 5610 will not power up without battery. With battery in it powers up almost then stops, front light goes out, have to remove battery and reinstall for front light to come on then it will power up then off again.
  • Acer Master
  • 2,385 Answers
Yeah, it will work but no light on at off condition
Posted on Jan 10, 2013
  • David Haeusler Jan 10, 2013
    It only turns on when battery is in but turns off just after booting up. Theer is nothing with the battery out
  • 3 Answers
SOURCE: Acer Aspire 5050 won't power on
If anyone is still having symptoms, I have the reason behind the problem. Acer uses a power input jack made of mostly plastic with a sheath of aluminum around it. This sheath has 2 main functions first is to solder it in place on the board, the second is to provide grounding. This very delicate little box made of mostly plastic has a little center node that is broken off if the laptop is drop hard enough, usually 2 feet or more. This center node provides one side of the polarity of electricity in order to power on the laptop. Upon breakage it slips back into the laptop never to interface with the powercord again, thus no charging. I would suggest everyone to look in the hole of their power input jack and you will probably see yellow plastic surrounding a silver post that is dangling in a weird fashion.
Posted on Feb 13, 2008
  • 244 Answers
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
Posted on May 08, 2008
yogesmaha
  • 69 Answers
SOURCE: acer aspire 5610-4491 laptop... NO POWER
remove battery and again insert it... then connect the a/c supply to the laptop and then check whether the power led is on or not .. if yes then on your laptop ..
Posted on Jun 17, 2008
SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Posted on Feb 24, 2009
SOURCE: My Acer Aspire 3680 will not power up.
Try leaving the battery out overnight. Sometimes it takes a while for the internal electronics to go 100% dead. Also, try holding down the power button for 10 seconds; that occasionally helps. Alas, it looks like you have a hardware failure, so the above may not work. Is your data backed up? If not, the drive is easy to remove and aspire 3680s are cheap on eBay.
-Guy Macon
www.guymacon.com
Posted on May 05, 2009
Acer Aspire 5610 wont start
Trying doing a Hardreset
Remove the adaptor and Battery and press the Power for about 30 secs
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
Hello !! i have an acer aspire 5600 and the problem is that i cant power it on .without battery there is a light on charger but nowhere on laptop. when i put the battery it power on for a while and then it...
If you can not power it up without the battery then you have a bad charger.
The battery has just enough life to turn it on and then shuts it down due to a weak battery.
If you are going to buy a charger I recommend you take your computer in with you and make sure you can power it on without the battery.
Mar 28, 2011 | Acer Aspire 5600 Series 5610-2013 Notebook
On the front of my Aspire 5610, the red light is flashing next to the light bulb symbol
Light 'OFF' - you are on Battery
Light 'ON' - you are charging the Battery
Light 'flashing' - Battery BAD.
Time for a new battery :(
Aug 23, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610Z dead battery & malfunctioning power adapter
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Apr 29, 2010 | Acer Aspire 5610 Notebook
Wont power back on. only yellow light flashes
I have an aspire one AOD250 notebook and I have had to unplug and plug the power cord to the outlet on the side and it always gets my charger light to come on, try it
Apr 03, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5720 Laptop issues.
It could be the battery. So i'd try to find a store that sells batteries and replace the battery.
Manny laptops will shut off when the battery is dead. So if your laptop works without the battery and only connected to the wallsocket, it's definitely the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Aspire 5720-4984 Notebook
Acer 5610 not powering up
Try power drain by keeping the power button pressed for few minutes to turn it off then try turning it on again
Sep 08, 2009 | Acer Aspire 5610-4491 Notebook
Acer aspire 5610 plugged in with incorrect ac power adapter
Probably is fried- Your probably looking at around $200 for a refurb motherboard and then whatever your local tech place charges to install it. :( probably not what you wanted to hear- sorry
Apr 08, 2009 | Acer Aspire 5610 Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
