Question about Stanley 42 - 240 Top Read I - Beam Level
Vials leaked
Have replacment vials from Customer service.. How do you replace...  Wood 4' with brass rails
  • 10,865 Answers
Obtain a number one phillips screw driver and remove the small screws next to the vial. Pop off the cover and then remove the vial. Insert the new vial and replace the remaining pieces. Good luck
Posted on Jan 21, 2009
Accessories for microscope edu science 900 x
from a laboratory supplies retailer
try searching ---laboratory supplies on e-bay
Nov 30, 2016 | Sewing Machines
Error 2 in 5417R,how do i solve it?thanks
Error 2 on this model indicates that the imbalance sensor is tripped. If you run the unit with an empty rotor and it does not error, then it simply means that your load was imbalanced. Make sure to put vials into the unit opposite each other, as below.
If it displays "Error 2" with an empty rotor and you did not notice a vibration, then the imbalance sensor is broken and must be replaced. Do not attempt to run the centrifuge without the imbalance sensor, as serious injury may result.
I repair these machines, but you would have to ship it to me in Ohio, which would probably be very expensive.
Here is a rotor balance chart:
Aug 13, 2015 | Eppendorf Centrifuge 5417r Refrigerated...
Is there mercury in flu vaccines given to children?
The short answer is no.
The Food and Drug Administration (FDA) has approved several formulations of the seasonal flu vaccine, including multi-dose vials and single-dose units. (See Table of Approved Influenza Vaccines for the U.S. 2014-2015 Season.) Since seasonal influenza vaccine is produced in large quantities for annual vaccination campaigns, some of the vaccine is produced in multi-dose vials, and contains thimerosal to safeguard against possible contamination of the vial once it is opened.
The single-dose units are made without thimerosal as a preservative because they are intended to be opened and used only once. Additionally, the live-attenuated version of the vaccine (the nasal spray vaccine), is produced in single-dose units and does not contain thimerosal.
Thimerosal is mercury based compound but its use has decreased as most vaccines are single dose today.
Dec 22, 2014 | Health & Beauty
Why dose my 075av chainsaw over heat
its worn out its slap on the cylinder head an when its hot it seizes . use heaver oils then it smokes its a balance of time an metal , you might find some magic metal treatment that can help it but no promises its 30 to 50 for them vials of treatments. some say its the additives an they offer gum removers for these small engines.
Jul 25, 2014 | Stihl Garden
How many ants can i put in the uncle milton light-up gel colony
According to their site, one vial of ants (contains 30) should be enough. But they also sell 3 vials (90 ants). I would assume you shouldn't put anymore than that. You can contact the by email or telephone to check for specifics:http://unclemilton.com/contact/
Dec 23, 2012 | Uncle Milton Ant Farm Gel Colony
I am keeping a LUMINOX series 3000/3900 for my son while he is in prison. Should the battery be removed for storage? If yes, can I remove it, & how do I go about doing it?
I am not absolutely sure about this specific model. But I do know there can be concerns with some due to the fact that the radioactive-gas filled glass vials are more susceptible to damage during the battery change. Also the O-rings should be replaced or at the very least lubricated if the watch needs to be stored for a long period of time.
A reputable jeweler should be able to take care of it for you for around $15 to $20.
Hope this helps.
Dec 27, 2009 | Navy Seal Luminox Dive Watch
How do you access your health vials/ throwing axes?
Try going into the options menu and figure out the controls on controller setup or read your instruction manual.
Aug 06, 2009 | Sega Viking: Battle for Asgard for Xbox...
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Central air is not cooling this evening. We shut the system off for a couple of hours to make sure if it was not frozen up. I have taken the cover off the thermostat ..there are two vials inside---should I...
Neither. Your problem is simple. If you look inside your unit which is located outside. The compressor. There should be a silver, oval in shape, part usually affixed to the wall of the unit. This device, if swollen or mishapen, thats your culprit. Replacement cost is approximately $15.00. The only other problem you may have without looking at the unit is. It may have a serious leak that have allowed all freon to escape. If there are no freon your unit will not freeze up.
Aug 21, 2008 | Heating & Cooling
Stanley 42 - 240 Top Read I - Beam Level Logo
75 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
