Question about Kestrel 3000 Pocket Wind Meter
What is kestrel 3000 error e 1 - Kestrel 3000 Pocket Wind Meter
Replacing cargo strapping top of kayak
Just find strong nylon rope of the same diameter as is on it now, and re-string it all. Use nylon because it lasts better and is stronger than poly rope. Use a colour that contrasts with your boat colour.
Apr 06, 2014 | Current Designs 12 Ft Kestrel 120 Roto...
Nitro kestrel engine will not start
I would say either you are missing power to the plugs or it is a fuel issue.
Apr 14, 2013 | Cars & Trucks
My american audio radius 3000 shows error
see if you have a reset button on the radio my kenwood was doing that its a tiny hole on the front you need a pin to reset it its that small and it works fine now
Mar 04, 2012 | American Audio Dcdpro610 Dual CD Player CD...
Need 1 rubber eye shield for swift ferret model 747
Regards, Tony
May 10, 2011 | Swift Kestrel 826 (10x50) Binocular
Wearing glasses with my binoculars
There are no adaptors for this problem.
The Kestrel should have rubber eyecups. They are fairly thick and stiff but these need to be folded over to be used with glasses.
If that isn't working for you you could try this. Some who wear glasses remove the eyecups. The rubber unscrews. The eyecup is then replaced with the rubber from a bicycle inner tube. Stetch the inner tube over where the eyecups were sitting. This can be cut and folded to the right height to allow viewing with your glasses.
Just removing the eyecup and using glasses may result in you scratching your glasses on the metal eyepiece.
Aug 29, 2009 | Swift Kestrel 826 (10x50) Binocular
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
Error loading c:\progra~1\mywebs~1\bar\1.bin\m3plugin.dll
You have spyware infesting your computer, the mywebsearch browser helper object. Run either Adaware or Spybot Search & Destroy, either should get rid of it for you. If not, please post to this thread and I'll give you a link to manual removal.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Error
please unplug all external devices from the back of the system tower , unplug the power cable and push the on button on the system and count 1-20 replug the power cable and power on the system the issue wil be resolved
Oct 25, 2008 | Dell Dimension 3000 PC Desktop
Kestrel 3000 Pocket Wind Meter Logo
29 people viewed this question
Top Kestrel Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kestrel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
