Question about Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher
Spray arms don't spin on Smeg DWF 410 ss
Water is coming in OK. I have checked the mesh on the water inlet. it's clean. any time i check , the arms are in the same position.
  • mickbarker44 Feb 13, 2009
    Thanks, but everything is spotless. water circulates through the system. maybe it is not powerful enough to spin the arms. nothing on the top shelf gets clean. is it possible it needs a new pump or something?
    Scholar:
  • 93 Answers
Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
Posted on Jan 21, 2009
Why doesn't upper sray arm work?
  • Improper loading or over loading of dishes and glass ware that blocks the spray arm from rotating; check your user's guide for proper loading methods.
  • the holes in the spray arm can be plugged from food particles or other debris, like coffee grounds; remove the spray arm and clean out the holes; run water through the arm to verify there is no blockage.
  • check to see if the spray arm became disconnected from the feed tube or the feed tube from the water inlet feed hose.; reconnect hose or tighten down on hose clamps
  • check for any filter blockages; remove food particles and debris
  • the tub itself could be under filling, because of a restricted water inlet valve; pour 1 to 2 quarts of water into the tub of the dishwasher and run it; if the performance improves, replace the water inlet valve with a new one; DO NOT try to repair the old valve- it will fail once it's taken apart and put back together.
  • the circulating motor drives a water pump that rotates an impeller, which creates water pressure to go through the washer arms and out the holes. The jetting action of the water pressure exiting the spray arm holes propels the arm to spin...if the water pump impeller is worn, damaged, or impeded by food debris, the cleaning action will be greatly diminished; inspect and clean or replace the impeller if necessary.
  • If the aforementioned trouble shoot and repair methods do not correct the problem, then a more in depth diagnostic check will have to be done by a qualified repair technician to check switches that controls the water/drain pump, (if it is a dual action model for example); to verify if the switch or the pump itself has failed.
Mar 24, 2015 | Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Smeg dose not takein water
Is the dispenser door opening.....f not the the dispenser is faulty
It the dispenser is opening but the product dose remain plugged in the cavity, the top wash arm may not be turning.
Clean out all of the particles blocking the top spray arm holes and spin the arm to ensure ti turns freely.
Also check that there aren't any items placed it the top rack that could stop the arm from rotating freely.
Product not coming out of the dispenser id usually always due to the top spray arm . if it is blocked with particles you may not have been cleaning the filter in the sump properly and 'bits' of food ate passing th filter, Make sure the filter in the sump is well firmly in place.
The last important point is to always run the machine at 60 degrees or more You need temperature to do the job properly.
Nov 15, 2014 | Smeg Dishwashers
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Apr 11, 2014 | LG 24 in. LD-12BS6 Stainless Steel...
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
I have a smeg 12059 integrated dishwasher which will not spin. I have emptied the water from the bottom compartment , cleaned the filter and turned on and off at the mains and only the lights will come on...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Oct 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
Top level rack pots are not cleaned, spray head does not rotate but water coming out of sprayhead, no obstruting parts
Check and see whether it freely rotates, when turned manually. The spray arm rotates under water pressure from the pump inside the machine.
Check inlet water pressure and clean the strainer at the inlet hose end near th inlet to the machine. Check and clean the spray arm axle housing also
Apr 12, 2010 | Dishwashers
Dishwasher does not spray water just trickles out.
Ok this normally happens when there is a leak in the base
pull it out and remove both side panels
Do you see any water in the base
look on the left side there is a red bar which goes down to the botton lift this up and down you should hear the swich clicking make sure the rod is down then retry it
The micro screen maybe clogged but the main culprit may be the larger filter found inside the unit upon which the spray arm sits. It has sometimes significant calcium type deposits that I nearly completely cut off the water flow.
http://www.acmehowto.com/howto/appliance/dishwasher/check/sprayarm.php
Link above is how to check, your spray arms, to test.
Water comes into the dishwasher not through the spray arm.
It comes through the water inlet valve out of the hole on the left side of the tub.
The lack of the pressure could be if it is not enough water came into the dishwasher during the fill up time.
Add a 1/2 of gallon of water manually and see how the spray arm spins. If it spins better then the next step is to check the water shut off valve under the sink. Is it open all the way or not?
If it's fine then the problem is the water inlet valve. It could be blocked with hard water deposits or it's not opening all the way. In both cases it has to be replaced.
Apr 08, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher Logo
436 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
