Question about Clothing Accessories
Can you recommend an on-line cheap store for pocket squers?
    Master:
  • 519 Answers
Here's a fancy store with silk stuff: http://www.styleforum.net/t/329649/pocket-squares-polo-made-in-italy-suspenders-silk
Posted on Jan 10, 2013
What kind of cloth diaper do you recommend for babies with extremely sensitive skin?
Baby is sensitive to synthetic fibers, I would recommend a system of completely natural fibers- cotton or hemp diapers with wool covers and if the baby is sensitive to wetness, I would recommend a system with a stay-dry lining against the skin, like pocket diapers. You can have more cloth diapers recommendation for you baby's extra sensitive skin on Stoffwindeln.
May 08, 2017 | Health & Beauty
Diagnostic wont read
Usually the OBD plug is powered by the cig lighter fuse.
Sep 05, 2014 | 2006 Lincoln Navigator
Waht is the best kind of rechargeablebatieris for it?
I have had good luck with Radio Shack rechargeable batterirs. They are easily accessible, reasonable costs and hold a charge very well. Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Kodak EasyShare C143 Digital Camera
I put in my calculator integrate of (2^X) and the answer is root squere of 2/12 when theanswer should be X^3/3 how can I solve this, by the way my calculator is is a TI-89 Titanium
What do you really want to integrate? 2 to power x (2^x) or x squared (x^2). Look at the screen capture below. The command line shows you the syntax for an indefinite integral.
May 10, 2011 | Texas Instruments TI-89 Calculator
Fuel line headed towards motor meeting flexible hose. is the metal fuel line threaded with orings?
All newer GM models use a quick connect fitting for the fuel lines. They are not threaded and do not have a replaceable o-ring. You can buy a cheap set of disconnect tools from any auto parts store or sears. Another option would be to buy them on line. The cheaper tools usually do not work the greatest. One solution I have used is to make a small strip of sheetmetal and wrap it around the metal line. Using a pliers you can press the sheetmetal into the quick connect while pushing the flexible line towards the metal tubing. Once the sheetmetal engages inside the quick connect, pull the hose off. Be careful with the sheetmetal, because it can be sharp. I would recommend buying the more expensive removal tools, especially if this is something you do more than once.
Mar 28, 2011 | 2001 Oldsmobile Alero
Help
Simple 0.5(cos15 + (squer of 3).sin 15) =0.5(cos15+(3x3).Sin15) =0.5(0.9659+9x0.2588) =0.5(0.9659+2.3292) =0.5x3.2951 =1.64755 Zulfikar Ali ali_zulfikar@yahoo.com 989980221
Mar 09, 2009 | Super Tutor Trigonometry (ESDTRIG) for PC
My iPAQ won't turn on no matter what i do.
If you are saying it heats up the it sounds to me like the battery is not holding a charge anymore. Try to remove the batter and place the pocket pc in its cradle and turn it on if it works then you can be sure it's the battery. You can probably pick up a batery on Ebay real cheap. Or swing by your local BatteryPlus store and they can test the old battery and probably buy a new one in the store. I hope this helps Have a great day.
May 05, 2007 | Compaq iPAQ H3630 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Clothing Accessories Logo
1,024 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
