Question about ASUS A8N-SLI Premium Motherboard
Power supply not coming on
ASUS A8N-SLI Premium have it stripped down to only 24 pin plug installed and power supply does not come on - power supply has been checked and is good. Do I need to connect anything else?
  • zke9897 Jan 21, 2009
    Power supply would not come on. Removed 24 pin power plug from MoBo and shorted pins 14 & 15 of 24 pin plan, all fans came on. With 24 pin plug plugged into MoBo fans do not come on. Began removing components (video board, floppy disk drive, etc.) one at a time and checking power supply after each one was disconnected. Right now all that is connected is CPU and 24 pin plug, still power supply does not come on. The power supply is good.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Do you have a "switch" or are you "touch shorting" the motherboard connector for the power switch?
  • 112 Answers
First of all you need to connected the power supply connector, processor connector, hdd connector, cd rom connector.
check it
Posted on Jan 21, 2009
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Loses time and date, loses temp files, bluescreens on line alot
the time and date is down to the cmos battery change it for a new one.
the blue screens could be a number of things could be windows,ram,hard drive,power supply,cdrom drive,motherboard.
Feb 19, 2011 | ASUS A8N-SLI Premium Motherboard
Cant hear audio from my antec asus a8n sli premium computer
Try uninstalling the sound card from the device manager and then restarting the computer.
Let me know if this solves your problem.
Dec 30, 2009 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Power supply wont come on
I've check and that board uses an ATX power supply. that is your problem. slap in an ATX and you'll be good to go. Please be so kind as to rate this answer thanks and good luck.
Jan 28, 2009 | ASUS A8N-SLI Premium Motherboard
Keyboard stays on
I would first Reset the CMOS... do this by switching the jumper pin cap from 2-3 to 1-2 then give it power/and immediately power off.. then reset jumper cap position to original spot... the jumper can be located usually near the CMOS battery.
Jun 01, 2008 | ASUS A8N-SLI Motherboard
Asus A8n-sli premium with amd 64 3700+ proc
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
Feb 28, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Asus A8N-SLI Deluxe Problems Booting
Sounds like the power supply is overloaded. Is this a new configuration? Start removing components until it powers up. If it still doesn't power up, check to ensure you don't have a short in any of the connectors that you installed components into. Sometimes when a video card, memory DIMM, or whatever, gets installed, there is a chance that a connector pin will get crushed and short out to nearby pins. If none of those work, you might want to try a larger wattage power supply. Good luck.
Nov 24, 2006 | ASUS A8N-SLI Motherboard
ASUS A8N-SLI Premium Motherboard Logo
111 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
