Question about Axiom Spark 4.0 USB Tail Light Red
Can't charge the axiom spark tail light
How do I take off the breaklight housing unit on a izuzu axiom?
Are you talking about the tail light assembly or the back window
Jan 19, 2015 | 2002 Isuzu Axiom
Axiom 49 not detected by reason 5
Open preferences. Go to Control Surface tab.
Click Add. Select M-Audio as manufacturer.
Choose Axiom 49
Make sure the ports are set right.
Controls IN Port = Axiom 49 Hypercontrol In
Keyboard Port = Axiom 49 USB A In
Controls OUT Port = Axiom 49 Hypercontrol Out
if it hasn't detected yet then restart Reason.
Make sure the power on the Axiom is on.
If you still have issues the USB port on the Axiom could be bad.
Oct 01, 2017 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
I have an 86 cutlass runs great, however I'm having some electrical problems. The tail lights won't come on and if they do they won't turn off. I've replaced the alternator and the b
can i suggest you kill it !!!!!! sorry but there is a draw on the battery ,,,, disconnect each item one at a time till battery dont spark at lugs when you disconnect them ,,, seriousy loossen lug on battery and if no power draw no spark wil be present... maby alittle one cos radio takes a really small current
Feb 12, 2012 | 1986 Oldsmobile Cutlass Supreme
What is an average milage of 2002 Isuzu Axiom, because it seems like I'm fill up my tank every two days.
a smple tune up can help you gas mileage. new spark plugs, air filter, fuel filter, right tire pressure, and if you want to go an extra step get a can of carb cleaner, take off your throttle body, and clean it out. i did this to my wifes axiom, its simple and doesnt take much time.
Oct 13, 2011 | 2002 Isuzu Axiom
How do you change the brake light
ether it is in the trunk or unscrew the tail light cover an replace
Nov 10, 2010 | 2002 Isuzu Axiom
How can I remove a tail light assembly to replace a lamp?
Posted by Pmlove509 on Aug 30, 2010
James spams again.
Aug 30, 2010 | 2003 Isuzu Axiom
2002 Isuzu axiom cluster lights and tail lights out
Don't try a higher fuse , it just makes things worse by adding extra burn to the problem.. First make a test lamp with a 21w bulb ( indicator size) .You now have a bulb with two wires attached , insert the "test bulb" across where the fuse should be.
When you switch on the circuit concerned it will glow BRIGHT as it is getting a POS (+) and a NEG (-) ie blowing the fuse (short circuit) in the fuse box and therefore a BRIGHT bulb.
As you disconnect and eliminate or disturb the problem the bulb will immediately glow DULL ( in series contact now) and no longer a short circuit . As you check the circuits the illumination will change and, your on the money ! Let's know how you get on , Good luck
Mar 05, 2010 | 2002 Isuzu Axiom
I can't seem to get the tail light off to change the bulb, how do I do this
Open the rear tailgate and remove the two screws that hold the tail lamp assembly in place.Now there are two alignment pins that hold the lamp in place, you must use a screwdriver or other flat device and lightly pry the lamp your working on. If you are removing the rear left (driver side) then pry back outward to the left. Alternately, if you are removing the right rear tail light, pry outward to the right. Do not try and pull directly back. The pins will prevent the light from coming out. You have to pull left or right, depending on the light your removing. Good luck.
Jan 05, 2010 | 2002 Isuzu Axiom
Isuzu axiom tod warning light flashing
You might have an engine misfire? I would check and replace all your spark plugs as mind was doing this exact same thing several months ago!
Jun 23, 2009 | 2002 Isuzu Axiom
How to replace tail/stop light for a 2002 isuzu axiom
remove the hardware (2 bolts) then wiggle to loosen, now pull outwards (pull somewhat hard) towards the sides to clear some kind of guide. Then towards the rear<
Dec 16, 2008 | 2002 Isuzu Axiom
Axiom Spark 4.0 USB Tail Light Red Logo
309 people viewed this question
Top Axiom Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you an Axiom Cycling Expert? Answer questions, earn points and help others
