Question about Garden
Enercon heat pumps manual SCehw0193302 - Garden
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
Heat pump is not working
Call for service.
Check breaker.
Rheem does not post service manual as does AO Smith
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Gene
h
Nov 11, 2013 | Rheem HP-50RH Hybrid Heat Pump Water...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
What does HP5 mean on my heat pump?
please refer to page 51 of this manual. http://aquacal.com/heat-pump-information/support/manuals/pdf/man-AT_HW_SQ.pdf
This explains that it is either due to your pump not pushing enough water.
Or the pressure switch is clogged or failed.
Or the wiring has shorted.
Check to make sure the circulation pump is not clogged and flowing freely.
make sure the filter is clean and flowing freely.
if this does not fix the problem, replace the pressure switch.
refer to page 56 for pressure switch identification.
Nov 18, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Panel reads lp error code
Loss of refrigerant, bad motor for the fan clean the coils and unit as described in the manual. Here is a manual from the Hayward website or here http://www.haywardnet.com/products/manuals/pdfs/Manual122.pdf.
Jun 04, 2010 | Hayward 116k BTU HeatPro Digital Heat Pump...
Jandy heat pump problem
here is the link. find your pump and download the manual for free.
http://www.jandy.com/html/productsupport/#manuals
Jul 12, 2009 | Heating & Cooling
Wont recognixe and disc I insert now
Hi Paul,
Do you work for Enercon, the company that makes Corona treaters? I have been working with them for over 15 years at Cryovac.
This may or may not solve your problem. Turn the power off. Then, Press and hold the 1/0 button for more than 10 seconds. Then turn your PS3 off again. Turn it back on to see if it reset the problem.
Nov 04, 2007 | Sony Playstation 3 (PS3) Console
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
