Question about Epson TM-L90
DIP switch positions
Hi, Does anyone know where abouts the DIP switches are location on the Epson TM-L90 so I can change there positions? Any help or advice would be most appreiated. Thanks, Pete
  • Anonymous Mar 12, 2014
    dip switch in tm-l90
  • darrell801 Feb 04, 2019
    I found where the dip switches are supposed to be, behind the little rubber thing you have to remove. However, when I remove the rubber piece all I see is the back of a circuit board, no dip switches??? any Ideas?
  • 944 Answers
Found them finally Pete - this is the service manual for the printer; http://www.posguys.com/download/TML90_Peeler_TRG_RevB.pdf Check page 45 of the pdf (page2-21 of the manual) for the location of the switches, the next 2 pages for the settings a bit clearer than on my previous post. also probably worth a read through the rest, in case there are some other possible solutions - I couldn't find one but you might see something that sounds familiar. Hope this helps, still trying to find a user manual direct link, will post it if i find one :)
Posted on Jul 02, 2007
SOURCE:
Epson tm t81 can not gives test print and shows state is invalid
If epson tmt 81 is not printing test page then check for dip switch below the printer and also reinstall the printer driver & configure the port properly
Oct 02, 2013 | Epson TM-T88III Thermal Printer
Dip switch settings for Epson TM U210D printer
I put the page you need up on my server.
http://www.itrsva.com/TM-U210-DIP_Switches.pdf
Jul 25, 2011 | Epson TM U210D Matrix Printer
Epson TM-U220PD printer network card problem - recognition
Did you change the dip switches? I believe that for the serial printer to work with ethernet, you need to have switches 2 and 4 on bank 2 set to on.
Jul 13, 2009 | Epson TM-U220 Matrix Printer
Epson t88iii will not print
I would like to say sorry to you I got my serial port mixed up with the parallel port. I have resolved the problem, it was a DIP switch change which needed to be set. If anybody can not get their computer to communicate with the printer then I would suggest they download the Epson Technical reference guide and read it thoroughly, but only use the guides for your method of connection which is dependent on your model of printer. I found that for a baud rate of 38400 DIP switch SW 1 numbers 7 & 8 should be switched to ON .I hope this helps some else.
Dec 12, 2008 | Epson TM-T88III Thermal Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
Driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Jun 03, 2008 | Epson TM-L90
How to make Epson thermal printer print darker?
Change the dip switches settings to
PLS DONT FORGET TO RATE AS FIXYA, THANKS!!
Apr 25, 2008 | Epson TM-T88III Thermal Printer
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
Epson TM-L90 Logo
1,309 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
