Question about Canon PowerShot A75 Digital Camera
Picture is nothing but gray and lines
As I am taking my pic the screen is clear and the object looks great. Once the picture is snapped, the result is a gray and white pic full of white lines. This is the way it downloads to the computer, too. Camera is not that old and is only used by an adult, so I would hope this can be fixed.
  • Anonymous Jan 21, 2009
    I have the same problem...
  • 1,573 Answers
See this link. If Canon determines that your issue is related to a faulty CCD (it seems that it is), they will repair your camera at no cost, regardless of warranty status.
Posted on Jan 21, 2009
Pentax optio e50
Try messing around with the settings so different pictures are achieved. is there flash? (I personally never use flash in any pictures I take). Just setting the ISO to manual doesn't do anything, There are specific values, setting it to a lower may help, there's also white balance and exposure you should take in account. The camera also isn't that great of a camera and I'd suggest getting a new one.
May 27, 2013 | Cameras
I have had my camera for not even a year and it recently started having this problem. Whenever I take a picture, the object will look fine in the display, but when I take the picture it gets horizontal...
If I understand you correctly, you're saying that the LCD display shows a normal picture when you are composing your shot, but that when you actually snap the shutter to record the shot, the resulting image has nasty lines across it?
That would indicate that the lens is fine, but that the image sensor itself or associated electronics have gone bad. If this is out of warranty, then you're likely out of luck.
Nov 26, 2010 | Casio Exilim EX-S5 Digital Camera
Cannot take a pic. No image in the LCD while pointing at an object or person.The LCD remains gray/black. Even if I snap a pic, no image.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 18, 2010 | Canon PowerShot SX100 IS Digital Camera
Pictures are almost white
check the picture selection rotary switch is set to "auto adjustment" or"programme auto",for perfect pics.
Aug 14, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Some pics have solid gray areas blocking part of the pic
Many digital cameras will display a thumbnail representation on the lcd and not the actual picture (for speed). So the problem is with the picture itself and if it is consistent in ALL of your pictures, it points to a problem with the imager. If the problem is not with all of your images, it could be a lighting issue. Try taking a picture of a solid white wall that is well lighted and see if the problem persists. If not, make sure your lighting is brighter.
Jul 11, 2009 | Cameras
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony dsc--w120 take a picture, the result pic with a whitish pic
Sounds like bad CCD. Needs t be replaced.
Mar 18, 2009 | Cameras
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Taking pic's
I am still working on this problem.
Jun 13, 2008 | Vivitar MAGNACAM Binocular
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Canon PowerShot A75 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
