Question about NetGear WGT624 Wireless Router
Netgear Wireless Router Problems
For the last couple of weeks, my internet kicks off and I have to reset my wireless router. I have a desktop that is hardwired, a laptop that is wireless and Vontage (which seems to have esclated my problem) all hooked up to it. My router is about 2-1/2 years old - do you think I just need to upgrade to a newer version
  • Anonymous Feb 01, 2009
    These routers usually die after a year or so.
  • 78 Answers
Use the process of elmination, disconnect Vontage, does the problem go away? If no then look at the modem (cable or dsl).
Hint! If you have a cable modem, make sure all cable connections are tight from the outside of the house, to every TV, and from the wall to the cable modem. Use plyers to tighten all of them.
Posted on Jan 27, 2009
Im having problems connecting to the internet after i got a netgear wireless dual band router to my pannaway modem
First check that router light is blinking. If not, need to repair or replace.
If light is blinking, you need to reset it. There will be a reset button back side of your router, press and hold it for 30 seconds. Restart your router and reconfigure.
Also check that you had enabled wireless setting. Ask here if problem still occurring http://www.vtechsquad.com/wireless-router-support/
Feb 24, 2013 | Computers & Internet
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
My xbox disconects when my computer and xbox are on at the same time. we have had the wireless router for 8 weeks and had no problems untill a week ago. (NETGEAR WGR614 wireless router)
You can try to restart the router. If that won't do the trick, you can look if they have accidently the same ip address. If they have, let the computer get an ip adress from the dhcp server.
Or just reset the router.
Hope this was helpful! :)
Apr 19, 2010 | NetGear WGR614 Wireless Router
AFRAID OF SOMEONE IS LOOKING MY COMPUTER
Very, very highly unlikely. It doesn't work like that.
Netgear is probably the manufacturer of your wireless card, and the rubbish software they give you is freaking you out.
Nov 18, 2009 | Actiontec (GT704WG) Router
Connected to the internet, but cannot browse any webpages
i think u have soem firewall isse in router also try to reset router then check .
reset switch in back side of router.pres it for 10 seconds .then it reset to defaults.
Mar 28, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Router won't log into it's IP address online
Is your desktop getting an ip address from the router?
You said that you reset the router, do you mean turning it on and off or pressing the reset button?
Aug 03, 2008 | NetGear WGT624 Wireless Router
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
105 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
