Question about Samsung WF337AA Front Load Washer
Instructions to replace flange shaft on samsung wf337a
I recently swapped a86 triton 4WD gear box for a 88 triton 4WD box.. the box is in but the tale shaft appears to be a different size icannot attach taleshaft ?
You mean the driveshaft? You can most likely change the driveshaft or the front of the driveshaft yolk out from the vehicle the gear box came out of.
Jun 04, 2017 | Cars & Trucks
How to remove the prop shaft that is bolted on my tranfer case on my 2003 AWD pontiac Montana
drive shafts are normally flange mounted and have 4 bolts that bolt the flanges together. Undo the bolts and slide the shaft along the spline to get it off the flange ( may need a lever to break the hold of the flange)
Jun 29, 2014 | 2003 Pontiac Montana
I have a 1995 GMC Sierra extended cab 2 Wheel Dr. 5.0 have vibration replaced everything in the front and tires trued wheels check for being bent nothing everything is okay but found out if you get a load...
The drive line angles are at fault and they come less of a problem when the diff angle is changed from the load. If you have a centre bearing in the drive shaft then the height at which it holds the bearing will have something to do with your problem. basically the angle that the gear box flange sits (say 2 degrees from vertical) has to be the same as the flange at the centre bearing flange as the same as the diff pinion flange . If the centre bearing is too high then the angle at that flange will be less than the 2 degrees and a harmonic vibration begins . Have an engineering shop that specialises in tail shaft manufacture (Hardy Spicer) check it out for you and they will explain what I mean. There are web pages that have detailed diagrams to help. Just go google and type in tail shaft vibrations and faults.
Oct 12, 2013 | Cars & Trucks
How to replace a broken closet flange. Flange is one piece PVC embedded in concrete.
Best way to remove the flange is to get a inside cutting wheel for a drill. Has a cutting wheel on a shaft to use inside of opening to cut the flange loose. You can cut it as close just below floor level and buy a flange that will fit inside pipe to help with not having to bust up concrete around flange.
One other thing you maybe able to use a long hand saw to help cut the old one out to replace.
hope this will be off some help, you should be able to repair this , just take your time and get old one cut below floor level
Aug 04, 2011 | Home
Got a leak from the rear differential on my truck, where the drive shaft goes in what made it leak
Hello Barry.
There is a flange attached to the pinion shaft that drives the gears inside the differential.
This flange is held to the shaft by a large nut threaded onto the pinion shaft.
On the flange there is a machined surface the seal rides on to retain oil inside the differential.
Sometimes rust can develop on this surface and tear the seal. Also debris could damage it as well.
Or in a worst case scenario the bearing that the pinion shaft turns on goes bad and allows the flange to wobble.
It will take an experienced mechanic a little over an hour to replace the seal.
The large nut on the pinion flange needs to be properly torqued and takes a proper torque wrench to do it.
Thank you for using FixYa.
KL
Nov 11, 2010 | Chevrolet C2500 Cars & Trucks
I have a GKS 7 1/4 circlur saw, I have lost my manual and when I put the blade on the saw will not turn. I can take the blade off and the shaft turns. I also need clear instructions on changing...
you might be missing the inner flange that goes behind the blade. You didnt specify what brand so for most saws there is a spindle lock depress that to stop the shaft from rotating, make sure the flange and possibly a spacer washer (might go behind the flange) are in place, install the blade with the teeth in the direction of the shaft rotation, install the outer flange and hex not or bolt that holds it tight, release the spindle lock and turn the blade by hand. UNPLUG SAW BEFORE DOING ANY REPAIRS
Aug 27, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
How do i replace a driveshaft for a 1997 lincon cotanental
I searched under 1997 lincoln continental and found this: Driveshaft and U-Joints
REMOVAL & INSTALLATION Town Car and Mark VII-VIII Fig. 1: The bolts retaining the rear driveshaft yoke-to-differential flange require a 12mm, 12 point wrench or socket to loosen them 91197p12.jpg
Fig. 2: Remove the bolts retaining the rear driveshaft yoke-to-differential flange 91197p11.jpg
Fig. 3: Separate the driveshaft from the axle flange and . . . 91197p13.jpg
Fig. 4: . . . disengage the driveshaft from the transmission output shaft 91197p14.jpg
Fig. 5: Insert a plug onto the splines of the transmission output shaft to prevent fluid from leaking out 91197p15.jpg
  1. Raise and safely support the vehicle.
  2. Mark the position of the driveshaft yoke on the axle companion flange so they can be reassembled in the same way to maintain balance.
  3. Remove the flange bolts and disconnect the driveshaft from the axle companion flange.
  4. Allow the rear of the driveshaft to drop down slightly.
  5. Pull the driveshaft and slip yoke rearward until the yoke just clears the transmission extension housing seal. Mark the position of the slip yoke in relation to the transmission output shaft, then remove the driveshaft.
  6. Plug the transmission to prevent fluid leakage. To install:
  7. Lubricate the yoke splines with suitable grease.
  8. Remove the plug from the transmission and inspect the extension housing seal; replace if necessary.
  9. Align the slip yoke and output shaft with the marks made at removal and install the yoke into the transmission extension housing. Be careful not to bottom the slip yoke hard against the transmission seal.
  10. Rotate the axle flange, as necessary, to align the marks made during removal.
  11. Install the driveshaft yoke to the axle flange. Install the bolts and tighten to 71–95 ft. lbs. (95–130 Nm).
  12. Lower the vehicle.
Jul 05, 2010 | 1997 Lincoln Continental
Ford 2001 econoline rear axle oil leak at drive shaft seal; how to repair/replace seal ?
if it is leaking from the front of the diff where the drive line goes into it you have to drop the rear of the drive shaft from the diff, if you look at the flange on the diff where the driveshaft bolted to you will see a nut, possibly about 25 to 30mm, you have to remove the nut and remove the flange off the spline of the input shaft of the diff, the nut is really tight and it is difficult to get enough pressure on the nut to "crack it" while the car is on the ground as there is not enough room to get a long bar on the socket to remove the nut. if you happen to get the nut loose and you remove the flange get a big screwdriver and pry the seal out of the diff, check the surface where the seal ran on the input shaft as it may have a groove worn into it, if it has the groove the new seal will still leak, they make a sleeve you can slide over the shaft to give the seal a good surface to run on, we call them a speedy sleeve here but not sure what they may call them there. replace everything in the reverse order that you removed it and don't forget to tension the big nut that holds the flange onto the input shaft
Jun 15, 2010 | 2003 Ford E150
I cant get the axle out of the front diff what is holding it in 2001 dodge durango
here is a diagram on how to get the front pinion seal out and it does mention how to get the axle loose. please do not forget to rate and comment about your experience with fixya today.
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove both half shafts.
  3. Mark propeller shaft and pinion flange for installation reference.
  4. Remove front propeller shaft.
  5. Rotate pinion gear three to four times, to verify pinion rotates smoothly.
  6. Record pinion flange rotating torque with an inch pound torque wrench for installation reference.
  7. Hold flange with Holder 6719 and four bolts and washers.
  8. Remove pinion nut.
  9. Remove flange with Remover C-452.
  10. Remove pinion seal with a pry tool.
    67189-dako-g28.gif Removing the companion flange
    67189-dako-g25.gif Measuring pinion rotating torque
    67189-dako-g27.gif Pinion seal installer
    67189-dako-g26.gif Tightening the pinion nut
To install:
  1. Apply a light coating of gear lubricant on the lip of pinion seal.
  2. Install seal with Installer C-3972-A and Handle C-4171.
  3. Install pinion flange onto the pinion with Installer C-3718 and holder.
  4. Hold pinion flange with Holder 6719A.
  5. Install new pinion nut and tighten nut until there is zero bearing end-play.
    CAUTION Do not exceed the minimum tightening torque when installing the companion flange at this point. Damage to the collapsible spacer or bearings may result.
  6. Tighten pinion nut to 271 Nm (200 ft. lbs.).
    CAUTION Never loosen pinion nut to decrease pinion bearing rotating torque and never exceed specified preload torque. If preload torque or rotating torque is exceeded a new collapsible spacer must be installed.
  7. Record pinion flange rotating torque, with a torque wrench. Rotating torque should be equal to the reading recorded during removal plus an additional 0.56 Nm (5 inch lbs.).
  8. If rotating torque is low, tighten pinion nut in 6.8 Nm (5 ft. lbs.) increments until rotating torque is achieved.
    CAUTION If maximum tightening torque is reached prior to reaching the required rotating torque, the collapsible spacer may have been damaged. Replace the collapsible spacer.
  9. Install propeller shaft with reference marks aligned.
  10. Install half shafts.
Apr 16, 2009 | 2001 Dodge Durango
The seal on the front axle on the passenger side is leaking.is it hard to replace myself.
here is a diagram on how to replace the front pinion seal.
please do not forget to rate and comment about your experience with fixya.
To install:
Apr 12, 2009 | 2001 Dodge Durango
Samsung WF337AA Front Load Washer Logo
35 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
