Question about Canon Office Equipment & Supplies
Problem on my Canon ip1880
After installation of new cartridge ink for Canon ip1880, my computer still displays "Ink running low" when I'm using my printer.
  • 30 Answers
Unplug the printer from power for a few minutes. If this doesn't reset it, then try the following:
PLUG the printer into power.
1. Press Resume button ( hold for 1 – 2 minutes )
2. Open the cover
3. Release the catridge and then put them in again
4. Close The Cover…
5. Turn Off, then Turn On
Posted on Aug 30, 2009
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Have installed new ink cartridge. still getting low inw warning
The low ink cartridge warning is nothing to worry about. If it prints, it prints. Most modern printer cartridges have a chip on it which lets the printer know when the ink is low. When you run low on ink, it sends a message to the printer which sends a message to the computer telling you to refill the ink. The problem is that it doesn't go away once you refill the ink. It still prints, you just get a notification whenever you want to print. You can still use it up until that new cartridge runs out of ink. :)
Feb 21, 2011 | Canon PIXMA MP240 All-In-One InkJet...
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have a problem with my canon ip1880,, an error message appears and it say "the following ink cartridge cannot be recognized. Printing cannot be executed because the ink cartridge may not be installed...
It could be a defective cartridge, or the contacts are broken on the carriage assembly. Either way, the Canon warranty is for one year and should be repaired at no charge.
Jun 30, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink
Better not to refill. Better buy a new original Canon cartridge. The reason being that some of the newer printers have sensors which can detect refilled cartridges and will cause more problems later.
Nov 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
77 people viewed this question
old marine
old marine
