Question about Baumatic Kitchen Ranges
ISL5SS need a new circuit board - Baumatic Kitchen Ranges
My black and red wires for my nds speaker circuit boards was severed. Can they still be used or do I need a new circuit board?
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
Aug 07, 2015 | Nintendo DS Video Game Consoles & Games
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jacuzzi hot tub , trips the circuit breaker, inspection found a burn't part Z-1 in on wiring digram. Can some one help with what a z-1 is Capacator?
If you have something burnt on your circuit board you will need a new circuit board.
begin with finding the chip number on the circuit board. this chip is usually located close to the transformer on the circuit board.
Rod
US Parts Center
888-521-6183
Jun 24, 2012 | Jacuzzi Pool & Spa
I have an old godman furnace GPM050-3 nedd to replace the circuit board, I allready got a new janitrol circuit board, but looks different, I need instructions on how to replace that
Look on the new board and the old boards to compare the markings where the wires a hooked at. For example "L1" on the old board would go to "L1" on the new board. All the wires on the old board sould have a counterpart on the new baord. Just switch them one by one so you don't get confused.
Nov 10, 2009 | Goodman GMS90703BXA Heater
Circuit board on AC unit at home was replaced, turned on unit and new circuit board burned also burned spots at the same locations as older board? What could be the problems?
You have something in that circuit that's pulling high amps or shorted. You need to determine what is in that circuit fan, compressor, contactor, wiring, etc and fix it first.
Until you fix that you will keep burning up boards.
Oct 07, 2009 | Heating & Cooling
I need to replace the circuit board in my wifes New Home Janome Memory Craft 7500. Where can I buy the circuit board and how do I install it
There are three circuit boards in the 7500. You should be able to get the correct board from any Janome dealer and if you need help installing it, I can help. It's very simple.
Aug 04, 2009 | Janome Memory Craft 9000 Computerized...
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
Kitchen Ranges Logo
74 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
