Question about Panasonic KX-T7736 Corded Phone (KXT7736)
Programming CO Pick Up Order
Is there a way to program which of my 3 CO lines this phone selects by default when I pick up the receiver to make a call? It currenly selects CO1, but I want it to pick up CO2 on just my desk unit.
Thanks,
Bill
  • Anonymous Mar 14, 2009
    The phone I'm asking about is the KX-T7736 --- the name of this Blog.
KX-t7433 There is another manual for programming, seperate from Operating. It is the Digital Super Hybrid System Programming Manual it is 518 pages and can be found at http://pdf.textfiles.com/manuals/TELECOM-F-R/KX-TD%20Version%204%20User%20Manual.pdf
Good Luck.
Posted on Jun 19, 2009
  • 23 Answers
It can be done. Need to know the model of the phone system
Posted on Mar 13, 2009
Remove dead co line
disconnect the line in system programming.
program*#1234, then 400 sp-phone , enter co line no.
then select disconnect and store.
Oct 29, 2013 | Panasonic KX-T7453 Corded Phone
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
When I pick up the receiver of my Lucent Partner 18D, it defaults to Line 4. How do I reset it so it will pick up Line 1?
Changing prime line access on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press ** then the lines in the order you want to access them.
press ** when your done the line access
Press feature "00" to logout
Jan 05, 2010 | Lucent PARTNER18 Corded Phone
I have an MLS-12D phone that needs odd programming - picking up the handset to call out should default to our main line (Line 1) (right now it defaults to a different line ? Line 2). Also, it should NOT be...
Well, there is a lot of things to do.
First, here is how to do Auto Line Select.
Is it only 1 phone that should be making outgoing calls? Or is it not place any outgoing calls ONLY on line 3?
Jul 30, 2009 | AT&T Lucent MLS-12D Phone
Default line
From your phone press PROGRAM dial 19 ENTER (or STORE) x ENTER (or STORE) then exit by pressing PROGRAM (or EXIT)
If x=0 it's no line If 1 (what you want) it's idle line if it's a 2-digit number 01-36 or the CO button, it's a line, and 3 or INTERCOM is the intercom.
Carl
Jul 03, 2009 | Panasonic KX-T7633 Corded Phone
When receiver is picked up, it opens the wrong line
. Changing line selection on a Partner system is done on either ext 10 or 11.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Hope that helps
Nov 23, 2008 | Lucent PARTNER18 Corded Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Panasonic KX-T7736 Corded Phone (KXT7736) Logo
212 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
