Question about Logitech Audio Players & Recorders
Broken power switch
I purchased a set of speakers from and the power switch was broken out of the box. there was no package damage.
  • 90 Answers
Contact asap and advise them of the situation. Because time is of the es-sense and the quicker you contact them, the quicker they will have you send it back, for a replacement, since it should be still under warranty. No sense of paying for a defective item.
Posted on Jan 22, 2009
Need power button for v2 premier
In most cases you can't just get a button, you need to buy a new computer case. If you're handy, you just need to put the parts in the new case the same way they're in the old one.
To help, you can go to the manufactures web site and get a manual to help.
A new case can be purchased from for as little as $20
May 27, 2014 | Viscom V2 Premier 17'' LCD Computer...
I have the Logitech X 540 5.1 speakers. When I used them on my HP Desk Top that had Vista they worked for a long time then all of a sudden stopped. I thought it might be my computer and I needed a new one...
Double check all of your connections and make sure everything is properly connected in the back of the sub woofer. Next, make sure that your audio jacks are plugged into the correct audio ports on *********** board, this is very import to make sure that sound is coming out and going to the proper channels. If the front speakers still do not work, recheck your audio settings on the motherboard. If all is folly and they still don't work, i would still recommend the same speaker set, as for the price they are amazing quality. But I will include a few other options within your price range.
Jan 14, 2011 | Logitech X-540 Computer Speakers
The power switch on the front no longer works. Where do I get a new one?
Check the cable where it connects to the motherboard. Check the cable where it connects to the switch, resolder any loose connections. Usually these do not break easily, but if it is broken you can buy a generic switch at newegg (
Jan 02, 2011 | Matrix 226R (VPR226R) PC Desktop
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
No sound condition on 60" mitsubishi CS 40601 (tube tv)
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 01, 2017 | Mitsubishi CS-40707 40" TV
I have a set of stereo computer speakers, Altec Lansing, Model #BX1121 ''Powered Audio System'' that has a subwoofer and a left and right speaker. When I plug the system in and turn the power on, I get...
i did the same thing when i was over seas, damn 220v, and all it did was blow the fuse in the unit, if you have an inline fuse (along the power cord) it might have blown there, if not you will have to take the unit apart and change the fuse, might be soldiered on the circuit board but its a relatively easy fix, just hope that the board itself didnt get shorted out, if so you will need to replace the system, i used this website when i was overseas and all my stuff got to me with in 10 days...
Dec 30, 2009 | Altec Lansing Multimedia Computer Speakers
Need power supply for a lcd sceptre x7g
try or google search for it, sry thats the best i can think of!
Dec 11, 2009 | Sceptre 17" LCD Monitor
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
I assume by charge you mean your power adapter. If this is the case you can purchase any universal power adapter for laptops within an acceptable wattage for your laptop computer. You can either visit your local best buy or circuit city store or purchase one at Hope this helps. :)
Oct 05, 2007 | Gateway M305CRV Notebook
Help installing speakers
Before tinkering with the unit,please check the manual that came with the product inside its box/packaging.Make sure that u have fully understood the instructions provided by the manufacturer. 1.Have you checked the power source at your house? 2.Does the product require voltage a specific voltage, 110V or 220V? 3.Have you checked if you have placed the connections inputs/outputs properly? 4.Another thing, have you tested the item before you bought and paid for it? If tested at the store, did it work? 5.Was it damaged during transport to your place? 6.Check also the warranty. Finally,call up the store because tinkering with it might void the product warranty.
Sep 24, 2007 | Creative Labs SBS-260 Computer Speakers
62 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
