Question about Bosch HBN 560570B / 560550B Electric Single Oven
Retractable function selector knob stuck
We have this fitted Bosch oven with retractable function selector. When cleaning the outside of the oven, the knob was pushed in and now we don't seem to be able to get it to come out again. It seems well and truly stuck!
  • Paula Carpenter Jul 02, 2007
    Thanks for the advice. Shortly after posting my problem we tried to prise the front facing from the knob in case there was a screw we could undo underneath. In the process the whole knob came out and we were able to push it back on and use the oven controls again! Easy!
  • Anonymous Mar 16, 2014
    ariston oven knob is stuck in - normally they would pop out when pushed in - can someone help
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
Facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Posted on Jul 02, 2007
SOURCE:
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
The temperature selector wont turn off
Sounds like your temp setting knob is bad. Try to reset the breaker and see what that does. Reset it even if the breaker is not showing tripped.
Feb 24, 2013 | Bosch Ovens
I have misplaced the manual for my oven and I need the self cleaning instructions. Model # RF365PXDQ0 Serial # FE2007966
First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
The manual is available here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203189075.pdf . If the direct link doesn't work, start here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number and then click Go.
I hope this helps.
Apr 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
How do I clean my oven? Model #RF354BXWD?
At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
Remove the racks and pans from the oven.
1. Move the Lock Lever to the right-the Clean position.
When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
2. Set the Oven Selector and Oven Temperature Control Knob to
CLEAN.
3. Make sure the clock and Start and Stop Times all have the correct time of day.
4. Push in and turn the Stop Time Knob clockwise two or three
hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
NOTE: Make sure the Start Time Knob is not pushed in.
5. After the Self-Cleaning cycle is completed and the oven has
cooled enough, the Lock Lever can be moved back to the left.
DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
6. After the oven is cool, wipe off any residue or ash with a damp cloth.
If needed, touch up spots with a soapy steel-wool pad.
Manual
Jul 30, 2010 | Whirlpool Ovens
Oven will not heat up but stove top works
Hello there
Please read the entire solution to see which best decribes your problem ok
first.
If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note… If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these,
Jun 27, 2010 | Kenmore Ovens
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
Do the knobs on bosch ovens retract when the oven is in use
Hello, Most of the temp. & select knobs do extend out, but not automatically. If you push the knob inward and release, they should individually "pop" extend out to allow them easier to function. As I indicated this is how most modern bosch work, with the acception of some models. Please provide your actual model number if you require further help. Hope that answer's you question, let me know if I can assist you further. Good luck, please rate this solution accordingly and thanks for coming to "fixya". Macmarkus :)
Apr 01, 2010 | Bosch HBL 5032 Electric Single Oven
Kenmore oven does not go on at all.
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Nov 20, 2009 | Kenmore Ovens
Bosch HBN 560570B / 560550B Electric Single Oven Logo
948 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
