Question about X2Gen MG19MY 19" LCD Monitor
Turned on my computer this morning and he picture was completely distorted. I can hardly make out any thing on the screen Any ideas?? I have had the monitor for a couple of years and really like it.
    Problem Solver:
  • 35 Answers
Replace the monitor. try another monitor. if another monitor is OK then it's time to get a new video card.
Posted on Jan 21, 2009
32L1300U
In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
Mar 26, 2014 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
Picture issue on start up
T-Con PCB. It is attached to the panel, under a metal shield. The LVDS ribbon cable runs to it from the Main PCB. It can be purchased separately for this model. For version SS03, the PN is: BN81-01312A
Mar 15, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
My display gets distorted
There is a simple test to narrow the possibilities. Connect your Thinkpad to a known working monitor using the video out connections at the back base of the computer. Then power on your R40 and see if the distorted screen develops on the known working monitor. If it does then you very likely have the BGA video problem, or Ball Grid Assembly problem and the problem is caused by a video/graphics chip on the motherboard. If you known working screen paired with your R40's base works fine, then you know it is a problem related to the screen itself and will call for either a new inverter or new backlight or new screen depending on further tests. But my bet is that it is the BGA problem which you can learn more about by searching for those terms on the net. There are services that repair ("reball") these BGAs but you have to remove the motherboard from the computer, or pay the service to do so. You can download the HMM, Harware Maintenance Manual, from IBM/Lenovo's site to get an idea of what is involved in opening up your R40 to extract the motherboard. This should help you narrow things down.
Apr 09, 2009 | IBM ThinkPad R40 2722 Notebook
Toshiba Satellite Laptop with distorted picture
Hi there again.
Yes it does sound like display drivers although it could be the bios graphics controller or the graphics chip so keep an eye on the startup screen for the same thing. In the meantime right click on computer, select manage from the sub menu, then select device manager, it will generate a list of devices, click on the + icon next to display adapters, right click on one from the drop down list and select uninstall, restart the pc and let the operating system re-install the drivers automatically, this should hopefully resolve your problem.
Please keep an eye on the bios/post screen because that could be an indication of more serious issues.
I hope this sorts out the problem for you.
Kind regards and thanks for using FixYa!!
Mar 14, 2009 | Toshiba Satellite A205-S5879 Laptop
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Computer loading/splash screen pixilated and distorted
if you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
Jan 02, 2009 | Computers & Internet
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Monitor
Adjust the pixels. Right click on desktop, properties, appearences, advanced and there should be a slide bar to adjust your pixels. Make them larger, ex. 1440X900 instead of 680X400
Jul 15, 2008 | E-Machines eMachines Monitor E15T4
X2Gen MG19MY 19" LCD Monitor Logo
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
