Question about RCA P46924 46" Rear Projection Television
Rca 46 in
Hi i got 3 tube inside one in the middle d'ont work is it something you can change??
  • 398 Answers
The only thing I have ever found that would make one of the tubes go out while the others stay on is a small high value resistor on the CRT board itself. It has been a while since I had that symptom but I remember the value of the resistor as 100k or 120k.
Posted on Jul 04, 2007
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA projector cleaning procedures?
Whatever you do you are better off to leave it alone or change coolant fluid in Tube its a Job doing it and you risk breaking Tube $450.00 unless you see the bugs in picture who cares.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
Philips 46 Rear Projection convergence off on part of the screen
you may have bumped the alignment rings on the convergence yoke on the red tube while doing the coolant as that could cause the symptom youre describing.
Aug 25, 2008 | Philips 46PP9302 46" Rear Projection...
Won't turn on and has a arcing noise
Block is bad,part number is 205064,sounds like a hole has burned in the part,its in front of the tv behind the speaker grill,snap off the grill and there is a panel,remove the panel and between the left tube and middle tube is the part it has red wires on it
Feb 23, 2008 | RCA P46810LV 46" Rear Projection...
RCA SCENIUM D52W136D
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you. to remove the screens remove the front grill, then remove the screws @! the bottom of the screen & if i remember right the top just sits on a lip, so gently try to lift the screen up.careful, these screens are expensive & you will have 2 or 3 of them. some of them are really easy to scratch.
Oct 22, 2006 | RCA P46924 46" Rear Projection Television
Rca p46771at won't come on post lighting.
Have you tryed to unplug for a while and plugging back in again.. Ff that dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Jul 25, 2006 | RCA P46924 46" Rear Projection Television
Have you tryed to unplug for a whiloe and plugging back in again.. if tha6t dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
RCA P46924 46" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
