Question about TJF Apps OBDII Trouble Code Lookup
Code p1780 in kia rio 2001
Fix my car problem
2009 Kia Rio code p0455 just came on. any suggestions on how to find and fix this new issue.
- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
also read this
http://www.kia-forums.com/1g-2001-2005-rio/82106-kia-rio-2003-error-code-p0455.html
Read more: http://www.engine-codes.com/p0455_kia.html#ixzz4Bkrh5aHZ
http://www.engine-codes.com/p0455_kia.html P0455 Kia EVAP Emission System Leak Detected Large Leak
Jun 16, 2016 | Equus 2009 Kia Optima Obd2 Can Code Reader...
How do I overwrite an Kia Rio 2000 coded-key
do not overwrite the key if you do you will not drive it again its coded for a reason, yes the box is pricey but that key and the box are married to never be separated
Oct 29, 2014 | 2001 Kia Rio
I have tha O/D OFF flasing in kia rio 2001
THAT IS THE OVERDRIVE IN THE TRANSMISSION
THE CAR MIGHT NOT WANT TO SHIFT TO HIGH GEAR OR OVERDRIVE SOME OF THESE CARS USE THE COMPUTER TO SHIFT IT TO OVERDRIVE AFTER IT GETS WARM THE THERMASTAT PLAYS A ROLL IN THAT WHEN THE ENGINE IS WARM THE LOOP IN THE COMPUTER CLOSES AND THE CAR WILL SHIFT TO HIGH/ OF THAT WON,T FIX IT THEN THE COMPUTER IS AT FAULT OR THE SENSOR IN THE TRANSMISSION IS BAD
Feb 26, 2010 | 2001 Kia Rio
2001 Kia Rio Check engine light
have purchased a haynes manual for this model car?
also you might go to a autozone parts store they have code reader & will check it free
Mar 12, 2009 | 2001 Kia Rio
Car not starting
Check the trans range switch, Po7XX codes are transmission related. The neutral safety switch for the starter i built into the trans range switch
Feb 28, 2009 | 2001 Kia Rio
2001 kia rio fuel pump does not work
Are you positive its the fuel pump? Have you tried running the pump with the return line off to see if it pumps fuel? They don't always have to make a noise.
Also refer to www.kiatech.info
Jan 10, 2009 | 2001 Kia Rio
Kia rio 2001 has no current to fuel pump engine cramks ok
Try replacing or swapping fuel pump relay its in the main fuse box close to the battery
TJF Apps OBDII Trouble Code Lookup Logo
Top TJF Apps Apps Experts
Are you a TJF Apps App Expert? Answer questions, earn points and help others
