Question about Motorola MC75
Wifi association timeout - Motorola MC75
Lost connection on all devices and at login keep getting " timeout"
Are you using a local wifi are is it built in? It may be all in the way your wifi is set up.
Apr 02, 2017 | Cell Phones
Why dose my galaxy tab 2 keep switching off after a min or two even thought the battery is full
In Settings-->Display, what timeout setting did you set? Check/change this as necessary.
Feb 16, 2015 | Samsung Galaxy Tab 2 GT-P5113 10.1" 16GB...
Fix no connection or no internet when wi fi is connected why does it sayno connect o connection timed out
Try this first....on the tablet go to settings and wifi.let it scan for your known router.once found do not try to connect but look for the arrow on right to try and set dchp etc.you should see a message somewhere on the page " Forget this network" click on it , rescan wifi again.this time your router will ask for the password.re input before timeout and it should be good to go.
Jan 18, 2015 | Tablets & eReaders
Can't connect wifi
Some things to check
  1. Make sure WiFi is powered on
    1. Go to Windows CE desktop
    2. Click on wi-fi power icon
    3. Click 'Turn on'
  2. On Windows CE Task bar
    1. Double-click on WiFi (First from left)
    2. Click on 'Wireless Information' tab.
    3. Select your network from network list
    4. Double-click on i
    5. Enter your network credentials
    6. Press OK
    7. Right-click on your network name
    8. Press connect.
Dec 18, 2014 | Motorola Mc2180 Data Collection Terminal...
Network timeout
Restart the computer first. Go ahead and try to connect again.
Jan 26, 2014 | Computers & Internet
I can not find the password/passphrase for wi-fi
its a setting on your iphone, my iphone has a wifi timeout set on it so if wifi data is not used it will power off the wifi to save battery. you can disable the option in iphone settings.
Apr 04, 2013 | Buffalo Technology Whr-g300n Wireless-n...
My childrens netbook says network timeout or max page when they click on the you tube icon, help
do unistall the toolbar associated with youtube,
or reinstal the browser again
Oct 03, 2012 | Sylvania G-Netbook
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Motorola MC75 Logo
228 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
