Question about Toshiba Satellite A45-S151 Notebook
One of the 3 Male Jack Prongs is broken off.
My Satellit A45-S151 Power Jack, that the external power cord plugs into, has one of the 3 Male Jack Prongs missing (broken off). What is this part called and can it be replaced? Does it require a trained technician or is this something a novice could do?
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
This will likely require some soldering, if you are referring to the jack on the dc converter (black box) you should exercise care when opening these there coiuld be hazardous electricity in it even if unplugged. (if it can be opened, many are permanantly glued shut) you can order replacements on ebay relatively cheap, usually $15-30.
Posted on Jul 20, 2009
I have a Prowler 720 pool cleaner. While the light comes on the device does not move, the fan on top is not spinning. I'm assuming that the drive motor is not working. Since the mechanism is basically...
The problem may be simpler than you think, Patrick. The robot's power cord must be plugged into the power supply port in a particular way. The male prongs on the robot's power cord are numbered, 1 through 4. Each of these male prongs must be plugged into the power supply port's corresponding number (e.g., 1 must be plugged into 1, 2 into 2, etc.). Do anything else and you get a motionless robot. I hope this helps.
Oct 20, 2013 | Pentair Prowler 720 Pool Cleaner
Help Me Please...my Toshiba A45-S151 Screen become garbled, seems like my LCD lost its black color....the screen display blur line,, and has no black colour.... it happens after i dissamsembly my laptop
Check the Wire Harness make sure it is back in the correct place and plugged in all the way into its designated plug. :) also, if that doesnt work then you can replace the LCD. Which is expensive.
Apr 14, 2010 | Toshiba Satellite A45-S151 Notebook
My power cord won't charge my toshiba satellite a45-s1202 . should i replace it?
need to be sure that power cord or power unit of Laptop is broken down
Oct 10, 2009 | Toshiba Satellite A45-S1202 Notebook
The brightness level
You need to use the Toshiba "Power Saver" console. Go to Control Panel -> TOSHIBA power saver. Click the Icon and use the console to adjust the brightness for the various power schemes. If you don't see the TOSHIBA power saver icon, go to Go to Control Panel ->Power Options and open that console. Select "TOSHIBA Power Saver" option in the "Power schemes" dialog box. If you don't have that option in the dialog box, you need to go to the Toshiba site and download the Power Saver installation file and reinstall it.
Jan 11, 2009 | Toshiba Satellite A45-S151 Notebook
I have a Hoover Windtunnel 2 upright vvacum cleaner. During regular use my wife turned it on and it staarted cleaning, then all of a sudden it stopped and then started again then stopped for good. I...
It sounds to me like the power cord has a short. To test your power cord you need a multimeter. Test continuity threw the power cord, from the male plug prongs, to the wiring inside the vacuum. You should get continuity from one prong on the male plug to only one wire on the other end of the power cord. If you test one prong but get a readying on 2 wires, then it is crossed. If you dont get any continuity on one or more of the wires, you have a short. A common place for a short in the cord is the male plug, you can find a replacement male plug at a hardware store and cut off the old one. When wiring the male plug, black wire goes to the gold post, white wire goes to silver, and green wire goes to the green post.
If your carbon brushes on the motor are warn, then that could cause the motor to stop, but other parts of the vacuum should still work so I dont think it is that.
Hope this helps.
Jun 27, 2008 | Vacuums
Toshiba satelite a45-s151 not turning on.
Toshiba Equium a60 PSA67E-00200D8J, I would like to know whow to install Igb ddr ram on this laptop details and advice would be great.
Apr 09, 2008 | Toshiba Satellite A45-S150 Notebook
Laptop doesnt start
there must be a problem with the voltage output of the adaptor... because many modern laptops react by shutting down when they encounter voltage ranges that they r not supposed to...
Feb 01, 2008 | Toshiba Satellite A45-S151 Notebook
Laptop doesn't start
Try removing the battery and reinsertit.
Or perhaps the on/off button is damaged .... (any shocks recently ?! ) Or there could be a more serious hardware issue...go on toshiba site maybe u'll find some info there ....
Jan 16, 2008 | Toshiba Satellite A45-S151 Notebook
Keyboard key not working
If it is just one letter then you most likely have a bad keyboard.
Try an external keyboard, if the 'c' is still not working with the external then it's probably some weird software issue. But, if the 'c' is ok on the external you will probably have to replace the keyboard. Replacement keyboard are pretty easy to find on ebay or the web and are usually very easy to replace.
Jan 14, 2008 | Toshiba Satellite A45-S151 Notebook
Computer constantly freeze up!
apply heat sink paste in your processor
heat problem
Oct 27, 2007 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite A45-S151 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
