Question about Nuance Dragon NaturallySpeaking 11 Premium
1155 error instal dragon speak software - Nuance Dragon NaturallySpeaking 11 Premium
DRAGON NATURALLY SPEAKING, WHEN i CLICK ON ICON I GET ERROR "ACTXPRXY.DLL DID NOT REGISTER ITSELF" CAN I DOWNLOAD THE FILE ?
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it http://youtu.be/rNDBRYdDXqo ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website http://support.nuance.com/compatibility/ . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
May 07, 2014 | Computers & Internet
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
Can Dragon 10 be installed on Windows 7, 64 Bit?
Apparently you need update 10.1 to work on a 64 bit system. Check this out: http://community.nuance.com/blogs/dragon/archive/2009/03/25/dragon-preferred-and-standard-10-1-updates-for-vista-64-available-in-english.aspx
Feb 03, 2013 | NRS Nuance Dragon Naturally Speaking 10...
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Aug 29, 2012 | Nuance Dragon Naturally Speaking 11.5...
Dragon Naturaly speaking XP editions not finding audio and video cards
and we can assume your computer is running xp correct? If not, then you'll need the updated Dragon, naturally speaking
May 29, 2012 | Dragon Systems Nuance Dragon...
I installed dragon, I think but I can't find it. Can you help me
Under the Start menu. Or in Program Files on the C:\ drive, you can find the .exe to launch the program. Or do a search for the program.
Mar 11, 2011 | Nuance Dragon Naturally Speaking 11 Home
Probleme of compatibility
What compatability is listed on the box? If it doesn't have Vista listed, you'll probably have to swap it.
Feb 05, 2009 | ScanSoft Dragon NaturallySpeaking 8...
Nuance Dragon NaturallySpeaking 11 Premium Logo
99 people viewed this question
Top Nuance Computers & Internet Experts
tony wahlman
tony wahlman
 Grubhead
Grubhead
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
