Question about Compaq Evo N610C Notebook
I have a Compaq Evo N610c and wanted to now what is under the right cover on the right of the mouse pad
  • JDTec
    JDTec May 11, 2010
    to the right and underneath ie the battery, on the left next to the touchpad, is the memory expansion bay.
  • 23 Answers
Hi babylove,
Goto this link, it explains everything regarding Compaq Evo N610c.
Hope it clears your doubt.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
If it helps you, please do vote for me!!
Posted on Feb 07, 2009
I have a compaq 620 and would like to turn OFF the mouse / track pad under the keyboard... please help!
Try these solutions: > 1.. F10 to enter bios setup at boot time
> 2.. Advanced
> 3.. Device Options
> 4.. Dual Pointing Devices
> 5.. Use arrow keys to select the pointing devices you want enabled
> 6.. F10 to save settings
> 7.. File-Save changes and exit
> 8.. F10 to confirm
>If the Synaptic's Touchpad driver is installed
touchpad/point stick can be
>enabled/disabled via the mouse properties in the control
panel applet.
Or:
> 1.. Start
> 2.. Control Panel
> 3.. Mouse
> 4.. Device Settings Tab
> 5.. Select the device and click on the enable or
disable buttons. "
If this helps, please rate. Thank you.
Jan 18, 2011 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
How do I adjust the sensitivity on the touchpad?
Try going to Start-->Control Panel-->Mouse
Under there should be an option that allows you to change the mouse speed
Jul 10, 2009 | Compaq Evo Notebook Keyboard N610C/N600c
Access to ram
The n610c has RAM accessible from underneath the laptop. There will be a cover with a logo looking like a computer chip near it. Should be 1 screw to access it.
Feb 05, 2009 | Compaq Evo N610C Notebook
Casing
The memory socket is located below and to the right of the keyboard. The panel is to the right of the mouse pad.
The keyboard needs to be removed. DO NOT REMOVE THE KEYBOARD CABLE! Remove the screw located in the middle lof the underside of the n610c. Slide the four tabs located on the top edge of the keyboard toward the space bar. The tabs are located to the right of the esc, the F4, the F8, and F12 key. Using a flat blade screwdriver gently lift the top edge of the keyboard, once it is lifted slide it toward the screen.
The panel covering the memory may require "gentle force" to remove.
Jan 04, 2009 | Compaq Evo N610C Notebook
Problems with Compaq Evo n610c
use a compressed air can to clean under and between keys.
(Power off)
Dec 17, 2008 | HP Compaq Evo n610c Notebook
Compaq evo n610C adding ram
Hi, the ram is located under a cover to the left of the mouse pad, you need a flat blade screw driver to pop it open.
Jun 26, 2008 | Compaq Evo N610C Notebook
Disabling touch pad
The touchpad should be able to be disabled through the BIOS.
Restart the computer, then push F10 to access the BIOS - if F10 doesn't work, try the other function keys and possibly the ESC key. You should find the option to disable the touch pad within the BIOS settings.
May 09, 2008 | Compaq Evo N610C Notebook
Re: my Compaq N600C laptop mouse
plz change pad or pad colour with dark colour and dont use transparent cover mous .
Feb 29, 2008 | Compaq Evo Notebook Keyboard N610C/N600c
COMPAQ EVO N610c MOUSE JUMPS
try reseating the keyboard and the mouse cables.
Nov 20, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
