Question about IBM ThinkPad 600E 2645 Notebook
Error 161 ,131 what does mean
I have the PC IBM 600 . when I open it alwayes give error 161 and 131 .how I can risolve this problem. thank's
  • Anonymous Jan 23, 2009
    Hi ,
    I have the same problem with naser1, same laptop , same model, os and specs. The only different of mine , after appearing those error numbers, it appears a picture of padlock, w/c obviously a password. Pressing Enter, it back again to the error messages with an arrow pointing to like a book picture. How to solve this problem.
    Hope any guru would help me, is very much appreciated. Thanks.
    rgrds,
    Alexis
    Master:
  • 413 Answers
These errors coming up are telling you that your time and date are not set. There is no real problem here but it is an annoyance. the only fix for this is to replace the bios battery on the motherboard. If you want to replace the battery the link below will bring you to a site that has instructions and pictures of how to replace the battery
http://images.google.com/imgres?imgurl=http://www.wlug.org.nz/archive/images/tp600-cover.jpg&imgrefurl=http://www.wlug.org.nz/ThinkpadNotes&usg=__IMwXFJPbxiA7_C7NEzZNvYu7vZI=&h=300&w=400&sz=38&hl=en&start=7&um=1&tbnid=CCnlsx2pUwSiNM:&tbnh=93&tbnw=124&prev=/images%3Fq%3Dibm%2B600%2Bbios%2Bbattery%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26hs%3DG9J%26sa%3DN
Posted on Jan 21, 2009
HOW TO SOLVE ERROR 08611 ON IBM THINKPAD TYPE 2645
If you downloaded IBM 600 repair manual, 8611 error is fixed by reseating the keyboard connector on the system board. Which means you have to unscrew 13 bottom screws to take out the keyboard.
Jan 06, 2012 | IBM ThinkPad 600X Notebook
Have error 8611 on my 600X. How to fix it? Thanks
Download IBM 600 repair manaul. It says to reseat the keyboard connector on the system board.
Apr 28, 2011 | IBM ThinkPad 600X Notebook
System board error on ibm pc 600e
you can change the board ,
Follow the bellow link for get the manual ,how to change the mobo.
http://www.scribd.com/doc/10960097/IBM-Thinkpad-600E-Hardware-Mainteinance-Manual
Let me know if you need more information
Thanks
Feb 13, 2011 | IBM Thinkpad 600 System Board Motherboard
Fan error in R52 IBM thinkpad
You get a fan error? That means the heatsink fan isn't working you will probably have to call lenovol (They replaced ibm).
Aug 22, 2009 | IBM ThinkPad R52 Notebook
IBM Thinkpap 600E 8611 error
http://www.repairspot.com/thinkpad_8611_error__disabling.htm
pls rate this solution if it works
thanks to choosing FixYa.
May 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IRe: IBM 600E
Hi, sorry I was out last night.
Errors 00161/00163/00173 mean you need to replace the CMOS/BIOS battery and update the time, date etc, like you did.. and Error 00301 means a keyboard error. Just press CtrlAltDel past this.. or try using an external PS-2 keyboard..
So, when you startup and then get to the errors, just press CtrlAltDel to restart, then tap F1 to enter the Advanced Settings and try to load Windows in Safe Mode, and let it do a Scan Disk.
It's possible that the machine won't be able to load any hardware drivers for the machine because the CMOS information might have been corrupted due to the flat battery, but try and boot into Safe Mode anyway and see how you get on.
This is a really old machine but still has driver and troubleshooting support at the Lenovo website, and it might be fun and interesting to resurrect..
Hardware Maintance Manual - June 1999: ThinkPad 600, 600E
On pages 109 and 115of the attached pdf file (actual pages 103 and 109), the Li-Ion batterypack part number should read 12P4064 replaces 02K7018.
c.gif Battery test utility diskette - ThinkPad 600/E/X
BIOS Update (Diskette) - ThinkPad 600
PCMCIA SelectaDock I/II driver for Windows 95/98 - ThinkPad 600, 770
c.gif Windows 98 installation supplement files - ThinkPad 600, 760, 765, 770
This is the Setup Guide for the thinkpad 600.
Of course, it may very well load Windows fine after a new battery and a scandisk and you'll find it has Windows 2000 on it, so maybe I'm jumping the gun with the Win98 stuff there, but let me kow how you get on..
Chris (ziraffa)
Oh by the way, if we are going to be using a different Solution thread this time, can you go back to the other page and rate it as Fixya! so that they can take it off the system? It saves the unrated pages filling up the servers..
Jan 17, 2009 | IBM ThinkPad 600E 2645 Notebook
Battery Life
As long as the battery is working properly it doesn't need to be changed. Laptop batteries are like any battery the more you use them the faster they wear out. If available you should always use the power supply.
Apr 06, 2008 | IBM ThinkPad 600 E Notebook
IBM ThinkPad 600E problem
might wann redo it or repiar it with orginal xp cd ok boot into cd
Jan 25, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
95 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
