Question about West Brass Pewter Bar Sink Hole Drain Small Midget Duo Strainer 2"
Can i install a garbage disposal in a bar sink with a 2"drain?
Can i install a garbage disposal in it?
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
Jan 26, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Repair a clogged garbage disposal
Use vacuum clean down disposal, and take apasrt tubular drain line to clean clog below sink:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Aug 28, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.
Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
Oct 18, 2012 | Swanstone KSLS-3322 Double Bowl Kitchen...
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I had to take it apart and now I can't seem to figure out how to put it back into the sink without it falling out.
If I understand correctly, your garbage disposal came loose from the sink basket.
The darker blue arrows point to the connector disc.
The connector disc rotates freely when garbage disposal is not connected to sink basket.
The trick is to lift the disposal into place with one hand.
Push up hard while keeping disposal
perfectly flat and aligned with sink basket.
Then use other hand to rotate connector until it catches on sink basket.
Before starting:
Disconnect the tubular drain pipes because these pipes will have to be re-sealed.
The electric wire and dishwasher hose can stay connected
If you are disabled or impaired, use a car jack or bottle jack to lift the disposal ... but go slow and don't lift the whole sink.
Now to reconnect the tubular drain pipes.
All drain pipes that were moved during the garbage disposal event should be taken apart.
Disassemble these pipes.
Clean the pipes and washers.
If washers are rubber, buy new ones.
If washers are plastic, re-use old ones after they are cleaned.
I use rectoseal on all tubular washers when installing pipes under the sink.
Coat the washers with plenty of rectoseal and the tubular drain pipes will seal first-time with no leaks.
Nov 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposer drain pipe is lower than the p-trap
Sorry you are doomed. The only other way to install is to have a plumber come back out and lower the drain in the wall.
Sep 09, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
West Brass Pewter Bar Sink Hole Drain Small Midget Duo Strainer 2" Logo
79 people viewed this question
Top West Brass Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a West Brass Plumbing Expert? Answer questions, earn points and help others
