Question about HP OfficeJet J4580 All-In-One Laser Printer
Error notification with new cartrige
New 3 color carteidge
eroor notification: "t least one "....Etc
i have replaced the cartridge twice
    Scholar:
  • 97 Answers
click on the setup button and scroll down to tools and under tools u would have clean print catridges and allign the catridges and it should resolve ur issue:
Regards,  raj_p5983
Posted on Jan 21, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
My new black ink cartridge doesn't work. The light shows like the other cartriges and there are no error messages. All 3 colors are working. - I performed the 'deep clean' for the black cartridge twice,...
I would like to advise you to remove the printer and uninstall the printer software from your PC, then reinstall the printer software to the PC, then connect the printer to be detected and installed. Now try to do the test described and see it it works out. Hope I could help . Good day
Aug 13, 2010 | Office Equipment & Supplies
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
Cartridge error 50C
Hi there Error 50c
RegOk hope it works.
arding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
color cartridge.
Mar 16, 2010 | Dell A940 All-In-One InkJet Printer
Cartridge error 50c
Hi there Error 50c
Please try this.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
color cartridge.
Dec 22, 2009 | Dell A940 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
color cartridge.
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Replaced color cartrige twice and says to check color cart..
We have a reset procedure on our web site at:
www.ccl-la.com/hp.htm The problem is cause by air in the ink feed tubes, the reset procedure will purge the lines and clear the error.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jul 17, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge problem
1. remove the cartridge and check the cartridge no. is it supported or not
2. if its supported then clean the cartridge contact and carriage cartridge contact with clean cloth and then check
3 some time what happen if color carteidge sircuit is gone bad then also this issue is comming so please check with new pair of cartridge
if issue same after done these steps then go to the neareast service center might be carriage pcb or flux cable or logic pca one of these part might be goes faulty
Nov 03, 2008 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet J4580 All-In-One Laser Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
