Question about Weller EC1201A Replacement Iron for EC1002 Series
EC1002 not heating up - Weller EC1201A Replacement Iron for EC1002 Series
My iron turns on and lights up but no heat how do i do a re start on it
first of all check the iron heat increasing switch and if it is working good..probably heat coil gone,,replace heat coil .
May 02, 2016 | Irons
I have black & decker x950 steam iron, it does not heat up properly. It heats quite low and turns shut off. Again on and shut off. How i can adjust its thermostat for more heat. HELP.
1) no voltage to receptacle
2)defective cord, or terminal connection
3) open thermostat
4) open heating element
see the diagram attached.
God bless you
Sep 09, 2012 | Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
The iron does not heat up
Hi.
Either wiring is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
Jan 15, 2010 | Steam Fast Irons
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Weller EC1201A Replacement Iron for EC1002 Series Logo
Top Weller Irons Experts
Are you a Weller Iron Expert? Answer questions, earn points and help others
