Question about Wasp WWS800 Handheld
Won't pair I cannot get the scanner to power up/down or pair with its base.
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Oct 21, 2013 | Honeywell 2020-5B Cordless Bar Code...
Motorola baby monitor won't link
I would say try disconnecting the battery and waiting fifteen seconds, then reconnecting the battery.. If you can't disable the batteries...
I would recommend seeing if there is anything interfering with the wifi between the monitors.
Oct 22, 2012 | Motorola Mobility Mbp16 Digital Audio...
Jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Aug 30, 2012 | Jabra GN9350e Wireless Headset
Hp c4580 on mac 10.6 won't scan
Based on the information you gave this may help:
Go to 'system preferences'
select 'print and scan'
Above the picture of the listed printer select 'scan'
Then select 'open scanner'
Follow onscreen directions from here.
Jun 08, 2012 | HP Photosmart C4580 All-in-One InkJet...
Three of the 4 scanners we own are all flashing blue and white and make double razzberry tones when scanning. What's happened?
they've lost their connection to the base. put them in the base, unplug them and plug them back in to let them pair up again.
Sep 30, 2011 | Metrologic Instruments MS9535 VoyagerBT...
My plantronics CS50 USB headset won't subscribe to the base, it just keeps giving 3 short beeps when the call button is pressed. Numerous attempts at resubscription and resetting have not had any...
I know this is an old post but I just want to share what I confirmed through Plantations. Hopefully it will help someone in the same situation. Sometimes, people buy replacements headsets and it should be noted the CS55 Headset does not pair with the CS50 base. While they headset looks identical, the only way to tell which headset you have is to open the battery cover and look under the battery. If you have a CS55 headset and a CS50 base, they will not pair.
Jun 24, 2011 | Plantronics CS50-USB Headset
I was curious, if i put my 2055 scanner on 12 volts, instead of the required 13 volts, will it hurt it?
You won't damage anything with 12 volts. Equipment built for use in automobiles will often have a DC input marked 13.8 volts because it's the voltage delivered by a fully-charged battery. But any supply around 12 volts will work. Just be sure the supply has enough current available (around an amp should be fine for a scanner), and that you get the polarity right when connecting it.
Jun 19, 2011 | Radio Shack Pro-2055 Base Scanner
I have a Delta single handle pull down sink faucet (about 1995 vintage) which is secured below the sink with a C-clamp. Below that clamp on the threaded shaft is what appears to be a metal sleeve (about...
It is probably rusted in place. I would recommend that you spray down with wd-40 or similar,tap on it lightly and let set for 10-15 mins. Then try to remove. If it still won't come off I would repeat a few more times if you are wanting to save the faucet.If not you can grip it with a small pair of vise grips and break off stud.You may also be able to remove it from the base of the faucet as it is screwed into it. Good luck and thank you.
Jun 01, 2011 | Delta Home
My toshiba satellite A505 won't start with the power button after I powered it down. Any suggestions???
try removing the battery and power lead to kill power completely, it sounds like the hibernate mode has hung.
May 28, 2011 | Computers & Internet
Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Jun 01, 2009 | Symbol P370 Handheld
Wasp WWS800 Handheld Logo
37 people viewed this question
Top Wasp Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jude24
Andrew Taylor
Andrew Taylor
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
