Question about Panasonic SC-DT100 System
COLLEGARE SCDT100 A TV LED PANASONIC
BUONGIORNO, HO COLLEGATO IL SISTEMA HOME THEATRE AD UNA TV A LED PANASONIC TX-L47ET5E TRAMITE INGRESSO AV2, MA QUANDO LEGGE IL DVD FUZIONA BENE, INVECE QUANDO VOGLIO UTILIZZARLA COME AUDIO DELLA TV (TV AUX) NON FUNZIONA. CI SONO DELLE SOLUZIONI? GRAZIE. SALUTI.
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
  • 13 Answers
SOURCE: panasonic dvd home theatre system,
Try restoring your unit to factory shipping conditions:
Press stop button on the main unit and (>10/ENTER) on the remote control at the same time for about 3 secconds, you would see the message "Initialized" on your tv screen, Once the message disappears from the tv, let go of the buttons. Try this and let me know.
Posted on Jun 10, 2008
stif_NEC
  • 441 Answers
SOURCE: Unlock Panasonic SA-PT660
I think you need this to be modified, if the is no software/firmware hack on to this, it should be hardware modification(for the remote or the dvd lens itself), like for Modding PS2 to play all sort of region/pirated disk.
Posted on Sep 11, 2008
glenmann62
  • 91 Answers
SOURCE: Panasonic dvd home theatre SA HT690
contact panasonic customer service and tell them the model# of the sub , just tell them you need a replacement , they will ship it out to you at a reasonable charge and sometimes they,ll send them out for free if the unit was just purchased because you can tell them it was,nt with the unit and that always seems to work for , Hope i was able to help and if you think i was helpful please leave a nice rating Thank you sincerely glenn mayer
Posted on Mar 05, 2009
SOURCE: Panasonic DVDn Home Theatre
Aiya u guy just simply say something abt F61
the actual problem is one of the audio output ic chip faulty (TDA89208)send back Panasonic at section 25 Shah Alam to repair it.
Posted on Jul 11, 2009
AIUTATEMI!!!! NON RIESCO A COLLEGARE INTERNET
Nintendo DSi / DS / Ds XL si connette a Internet tramite connessione wireless. ? necessario conoscere le impostazioni del router. Sono elencati di seguito i passi su come si intende accedere al router e ottenere le informazioni necessarie per voi da collegare.
Come accedere al router:
1. ? necessario conoscere il ipaddress del router. ? possibile fare riferimento al manuale o controllare il gateway predefinito del computer (Assicurarsi di collegare il computer al router tramite un cavo Ethernet per voi per ottenere il gateway predefinito). Fare clic su Start poi Esegui. CMD tipo sul piccolo riquadro in basso a sinistra dello schermo. Tipo IPCONFIG nella finestra nera e ottenere il valore della vostra gateway predefinito (che inizia con 192.168.xx)
2. Aprire un browser, digitare il gateway predefinito sulla barra degli indirizzi del vostro browser. Vi chieder? un nome utente e password. (Consultare il manuale del vostro router o inserire un messaggio in modo che io in grado di fornire il nome utente e la password del router)
3. Vai alla pagina delle impostazioni wireless del router. Cercare il SSID o il nome di rete e theNetwork chiave o passphrase. Si pu? personalizzare in modo che si pu? facilmente ricordare i dettagli.
4. Assicurati di collegare al proprio SSID e inserire la chiave di rete per renderlo sicuro.
Ora che sappiamo gi? le impostazioni del router poi il suo momento di collegare il Dsi alla rete.
1. Vai alla Nintendo Wi-Fi Impostazioni di connessione del Gioco
2. Ricerca di un Access Point (SSID)
3. Seleziona la tua rete (SSID), Se si dispone di una rete aperta, basta cliccare su "OK" e dovrebbe funzionare bene! Se si tratta di un lucchetto rosso, sar? chiesto di specificare una chiave di password o di rete. Questo ? il motivo per cui reson accedere al router.
4. Verificare la connessione.
Sep 03, 2011 | Nintendo DSi XL Burgundy
Il mio Acer T180 non da più segni di vita nel senso che, collegando il cavo di alimentazione, non si gira nessuna ventola e non si accende nessuna spia L'unica prova che ho fatto è...
Sembra che il vostro alimentatore pu? essere morto, perdona il mio italiano, anche la if alimentazione non si accende non mean it effettivamente funziona, prima di cambiare la tensione, provare questo, scollegare il system, rimuovere la scheda madre battery, tenere premuto il potere pulsante per 30 secondi, rilasciare,, sostituire la batteria, plug-in e si accende,,, se quello non riesce, individuare i pin sulla scheda madre che il pulsante dell'alimentazione si collega anche, ci dovrebbe essere qualche altra cosa l? come bene, come reset, LED di alimentazione e HD LED, assicurarsi che il sistema ? collegato a sua volta e lo ob utilizzando un cacciavite tipo di lama e bridiging entrambi i perni di alimentazione con esso. I apoligise ma non sono molto bravo a itallian Quindi, se ho mescolato tutto mi perdoni ..
Sep 16, 2010 | Acer Aspireā„¢ T180 PC Desktop
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
Scanner
Questo spesso succede quando colleghi la stampante prima di aver installato il software, o quando non installi tutto il software.
Devi installare tutto il software presente sul disco, controlla anche il cavo usb, un cavo usb difettoso puo far funzionare la stampante e non lo scanner.
Se non funziona, fai un system restore (recupero del sistema? non mi ricordo come si chiama in Italiano.
Dicevo fai un system restore da Avvio>>programmi>>accessori>>utilita di sistema...
Questa procedura riportera' il computer come stava prima che Windows installasse automaticamente i driver per la stampante.
Dopo il system restore installa tutto il software sul disco della stampante SENZA collegare la stampante finche' esplicitamente richiesto dal programma di installazione.
Se non hai il disco devi scaricare i programmi dal sito Lexmark, che pero e' in inglese, o chiedere una copia del disco al rivenditore.
Qui c'e' il sito web della Lexmark : Official Lexmark Drivers and Software
In bocca al lupo.
Nov 20, 2008 | Lexmark X2500 All-In-One Printer
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Panasonic SC-DT100 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
