Question about Yamaha Office Equipment & Supplies
BROKEN BOTTOM FEEDER PLATE
NEED REPLACEMENT FOR BROKEN BOTTOM FEEDER PLATE
2 Suggested Answers
  • 1212 Answers
SOURCE: cigweld wire wasp mig welder wire feeder worn need replacement also operation manual and plastic feeder cable holder is broken need new one located in Mandurah W.A.
http://www.thermadyne.com/IM_Uploads/DocLib_1498_43-59.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_1673_CIGWEL56.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_4168_0-4949.pdf
http://www.thermadyne.com/IM_Uploads/DocLib_4143_0-5072.pdf
If your gun end is a Tweco, those are pretty much standard and readily available from welding supply houses. If the retainer for holding the liner is broken you would get that through Thermadyne.
Posted on Jan 16, 2012
I have a Juki8700 it does not seem to be feeding the fabric thru on the feed dog
ck presser foot tension. even with sightest presser ft tension goods should feed. next ck that your feeder plate is not loose or broken. take off the plate and see if u can move the feeders with your finger. tighten screws makinf sure the needle is centered inthe feeder plate hole. if this is not the problen then youe=r feeder plate teeth are too low or worn out. look up how to raise the feeders. the should be 1/8" above plate.
Jul 25, 2014 | Juki DDL-8700 Industrial Straight Stitch...
How can I fix my broken pet feeder?
Unlikely it is worth repairing if it is out of the one year warranty, as the replacement parts (if available) could be close to the replacement cost.
Jul 10, 2014 | Petmate Le Bistro Portion-control...
Xante envelope feeder won't lift
You have two (2) sensor that have to be made, the first one is on the bottom of the feeder and the other one is at the very top of or near the feed roller. When you block the bottom sensor the feeder should move up. If the feeder does not move up their is a problem with the cable that connect to the printer and the feeder or it could be the Motor control board that is inside the printer itself. I would check the connection first, covering the bottom sensor if it does not move up most likely the control board is bad. Also make sure that the feeder in position switch is also made by the feeder plate.
Nov 07, 2013 | Xante Ilumina Digital Color Press Printer
Broken feeder plate
It would be called a Needle plate or Throat plate. Good luck finding them, I've never seen anything in the domestic machines... and industrial machines are just as difficult to find. Check with whomever you purchased it from. Perhaps they can direct you to a parts place.
Nov 29, 2012 | Yamata FY700 Mechanical Sewing Machine
Cigweld wire wasp mig welder wire feeder worn need replacement also operation manual and plastic feeder cable holder is broken need new one located in Mandurah W.A.
Jan 08, 2012 | Welding Tools
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
We have broken the salad dish lid in our fridge and need a replacement. we cannot find the model number and need to order a new one. Thank you
Look inside the refrigerator on the side walls. Some are located on the bottom front above or behind the kick plate.
Aug 08, 2010 | Refrigerators
Displays check document, nothing there
The paper path arm on the doc feeder popped out of the bracket. You need to remove the two sides of the ADF main feed unit, this allows you to open the unit further. take out the two scews holding the bottom gray plate on, you will find the actuator laying next to the bracket on this gray plate. snap it back into the bracket and reassemble. this happens when a misfeed is yanked out of the feeder.
Mar 30, 2010 | Canon LaserCLASS 510 Printer
Document Sheet Feeder
hi im jules_09,check the pick up,bottom plate and feedout motor then the rollers,then the fed belt,also try lobricating the gears,check all parts first before replcing it save you time and money.
Nov 08, 2007 | Ricoh Aficio 450 Copier
HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Oct 14, 2007 | HP LaserJet 1320n Printer
14 people viewed this question
Top Yamaha Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
ray gallant
Are you a Yamaha Office Equipment and Supply Expert? Answer questions, earn points and help others
