Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl does not heat- fuse has continuity (OHM test) help.
    Novelist:
  • 140 Answers
I am assuming that your microwave turns on and everything and that when you press the start button the table turns and all. This tells me at least that all the switches on the door are working properly and since your fuse is not blown you have power to your control panel. That being the case the magnetron (the part that does the cooking) is bad and needs to be replaced. If you are a do it yourselfer and can find the magnetron through a local supply house or the internet, replacing it is pretty straightforward. Unplug the microwave and take the cover off just a handful of screws. On the control panel side and behind and on top you will see the magnetron with cooling fins on it. The magnetron is usually held in place with three to four screws and has about 3 to four wires coming from it and going to a couple of places. These have terminals on them that unplug and there is no soldering or desoldering to do. Unplug the wires and be sure to make a small diagram as to which one goes where. Get a new magnetron and replace it. Put the cover on and you are back in business. God bless.
Posted on Jan 22, 2009
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
Microwave stopped heating
You likely need a new magnetron While the cabinet is open look for melted wires, fuse, burned traces on the circuit board, continuity on thermal cufoffs. If the fuse went then the capacitor needs replacing. Relays on microwaves stick sometimes and may need a firm hit or replacement. Check the continuity of the door switches (keep the resistance below .2 ohm or replace them too.
Nov 27, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1400 Spacesaver is not heating things up AGAIN!
It's what, about 7or 8 years old? I'd buy a new one on sale. Probably not worth messing with just to squeeze out another year or two. You can pull out the Capacitor and take it to any electronics appliance repair place and have it checked for little or nothing, but if it's bad and you order a new one you have no microwave for a while. IF that's the ONLY thing wrong you're back in business.
Mar 30, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker 1800 microwave looks and sounds as if it's heating, but no heat is generated when turned on. Is it repairable, and if so, how?
(((The fuse is located inside the unit along side the magnetron)))
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE XL 1800 Spacemaker Not Heating
have you check the fuses, maybe its open, orthe hv diode.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
