Question about Chauvet Fc-w Fcw Wireless Remote For H900 H1100 H1300
Chauvet remote pinouts I need to use a generic remote on the H1300 smoke machine. It has a 5 pin din plug for the remote as well. Which pins will trigger the smoke
I have four 200b lights that i must have connected to a wrong device and all 4 blew fuses. I replaced the fuses but they continue to blow as soon as I plug them in.Any suggestions would greatly appreciate.
first need to know if the other device you connected it is with dmx and if not, the most likely need replacement on the circuit 8 pin controller dmx its easy to know the locate its the circuit most close to the input signal, I hope you test the input volt regulators and are well, if not also need more data presents fault.
Feb 16, 2013 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here: http://el34world.com/charts/Schematics/files/peavey/peavey_mark_3_bass_with_pa.pdf
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
Have a q-mix chauvet stage light goes thru all motions but light wont come on even changed bulbs and fuses alright
Chauvet uses a 16 amp Triac to control the power to many of the 120 volt lamps in their products. The Triac MAY be blown in your unit. If a bulb shorts, this blows the Triac.
I use Diigikey,com part number 497-2397-5 as the exact replacement. The generic number is BTA16-600BRG
Look for a part with this number on an aluminum plate and test the device. Also look for loose wires in the unit.
Sep 12, 2010 | Chauvet Followspot 400g with Stand
Just got hold of a Roland R8 but no power supply - any ideas?
Well, you might try:
http://www.yub.com/products/?productID=3190411
The supply has a three pin connector and supplies +10 and -10 volts at unknown current. Don't have a pinout.
I am sure you can cobble something up if you can''t find the ACH120 official power supply.
You would need to find the pinout polarity to connect power if you have to make your own. One would taake unit apart and trace those input wires to something that would define the polarity. First find ground, then look for input filter caps which will tell you the polarity on the pins.
Jan 30, 2010 | Music
Zoom 9030 works well after all these years there is a memory battery that needs to be changed every 5 years or so. The only problem is when I plug in the 8050 foot controller it won't change any patches...
It is LIKELY that one or more pins and or wires in the remote cable are broken.
These MINI DIN connectors are "tender" and are easily broken and wires flex at the back of the connector and are broken.
FIRST check that all pins are present at BOTH ENDS of the cable.
NEXT use an ohmmeter to check continuity of each and every pin end-to-end. I suspect you will find one or more broken.
Be aware that repairing this cable requires patience and steady hand as the pins are so close together it is easy to have solder bridges, etc. Sometimes just opening the connectors are a problem to access the pins. Sometimes the cables are MOLDED and those are UNREPAIRABLE other than cutting off the bad conector and replacing it. You can usually buy replacement connectors at DIGIKEY.com and or Mouser.com. You have to CAREFULLY select the apporpriate pin configuration from the catalog page. One needs a small soldering iron and magnifying glass to work on the cable.
USUALLY the wires go from pin to pin. Also a shield on the cable has to be dressed and connected usually. You may find the shell of the connector tied to a pin or just the sheild of the cable.
Jan 08, 2010 | Zoom Music
WHAT TYPE OF POWER CORD OR POWER PACK WILL I NEED WITH THE CHAUVET DMX 60 TIGER WHICH I LOST AND THE WEB SITE WERE I COULD BUY ONE
If the power connector on the back is a 3-pin socket then get a standard IEC power cable. If it is a small rounded socket then get the corresponding power supply. The unit pr user manual should give the correct specs on the required voltage, polarity, current consumption, etc.
Sep 27, 2009 | Chauvet Dmx 55 Dmx Controller
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Plug from V-Amp 2, 4 pins
Hi Adrian
Just emailed you a pinout diagram for the vamp power supply. Hope that was what you were looking for. Cheers
regards
robotek
Oct 29, 2008 | Music
Chauvet Fc-w Fcw Wireless Remote For H900 H1100 H1300 Logo
43 people viewed this question
Top Chauvet Music Experts
Vito Vacirca Jr.
Are you a Chauvet Music Expert? Answer questions, earn points and help others
