Question about IBM (09N5424) Motherboard
FOR IBM MOTHERBOARD REV 1.6
Q1 :WHAT IS THE MAX POWER OF A PROCESSOR TO UP GRADE?
IS IT ONLY2.4 GH OR ABOVE THAT?
Q2:CAN I APPLY A DDR2 RAM STICK ?
  • Anonymous Apr 08, 2009
    IBM :1.6 PN 8898474 MOTHER BOARD DRIVER
    Scholar:
  • 54 Answers
I believe the fastest CPU you can install in that motherboard is a Athlon XP 3200+ (2.2GHZ) socket 7 CPU.
That board uses eaither DDR 1 or SD-RAM and is definatly not compatible with DDR2 which uses a different connector on the motherboard (more pins)
Posted on Jan 21, 2009
WHERE IS THE IBM REV: 1.6 MOTHER BOARD DRIVERS
Posted on Jan 07, 2011
I have a ibm rev 1.6 and I would like to know if I can put 1 gb of ram in it?
You would need to tell us what the motherboard model number is.
Apr 05, 2013 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
What kind of memory can I use in my 6282-75u
IBM 300GL 6282-75u
IBM = Manufacturer
PC300 = Series
PC300 GL = Subseries
6282 = Machine Type
75u = Model
Intel Pentium processor or Intel Pentium with MMX technology, and max frequency rate ('Speed') is 200Megahertz. (200MHz)
Woo-hoo!
Two ram memory slots.
EACH slot can hold a maximum amount of ram memory -> 64MB
TOTAL ram memory amount for motherboard is 128MB (Woo-hoo!)
Ram memory is SDR Sdram. Commonly, but mistakenly, just referred to as Sdram.
Has 168 gold plated contact pins. 84 on each side.
Two Locating Notches on the bottom of the ram memory module.
(Two Side Notches. One on each side)
http://en.wikipedia.org/wiki/File:SDR_SDRAM-1.jpg
Non-ECC and 100MHz as shown above. (PC100) [ DIMM ]
I don't know if you can just use a 128MB ram memory module ('Stick'), in ram memory Slot 1, or not.
Me?
I would try it. May have to reboot up to 4 times for BIOS to recognize the ram memory. May NOT have to.
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Under the bold white heading in the black bar -> Technical manual
,click on the blue -> [+] Click for files.
It is a PDF file, and the HMM for the IBM 300GL-6282-75u Desktop PC.
(Hardware Maintenance Manual)
Cheap buy on PC100 - 128MB - ram memory modules,
http://www.weirdstuff.com/cgi-bin/item/23513
Regards,
joecoolvette
(PS.
You have a D.I.P. switch on the motherboard. SW1
Has 4 dip switches, numbered 1 through 4.
The positioning, (ON or OFF), determines the 'speed' support for the Processor.
Page 26 - PDF file page, Page 14 - Actual manual page )
Aug 24, 2012 | IBM (61H0382) Motherboard
Motherboard for compaq pcsr5109uk have upgraded to 1,5 GB this adding a 1 GB ram since doing this pc will not boot up,pc has said that the mother board has died this has only started since new ram have...
From what you have stated, the original ram memory was two sticks of 512MB.
It's PC2-5300
(DDR2 Sdram at 667MegaHertz)
When installing ram memory, and installing two sticks with one stick being larger, the larger stick of ram memory is installed in Slot 1.
This is the ram memory slot that is closest to the Processor.
(The Processor reads Slot 1 first)
On the motherboard it has DIMM 1 printed next to Slot 1.
The 1GB stick should go into Slot 1 (DIMM 1), and the 512MB stick should go into Slot 2 (DIMM 2)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077654&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3457899
Scroll down for the motherboard illustration, and photo.
Won't boot up with the original ram memory installed again?
1) What type, and size of 1GB ram memory did you install?
2) What ram memory slot did you install it in?
3) Did you follow anti-static precautions BEFORE you put your hands inside your computer, and BEFORE you took that ram memory stick out of it's protective anti-static bag?
[Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it.
Poof!
No computer.
Computer unplugged from power, computer on a table, computer case open, TOUCH the metal frame to relieve your body of Static.
{A couch, bed, or directly on a carpet floor are HIGH areas of Static]
Before you answer my questions try this;
If the two sticks of 512MB PC2-5300 are still installed, follow anti-static precautions, and remove them.
Take a pencil eraser, and clean the gold plated contact pins on the bottom of each ram module. (Stick)
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(The above example is DDR Sdram, not DDR2 Sdram. I posted the link so that the gold plated contacts are clearly shown.
DDR Sdram has 184 contact pins.
92 on each side.
DDR2 Sdram has 240 contact pins.
120 on each side)
Remove the eraser dust with air. Use a can of compressed air for computers, or air pressure from your mouth.
Reinstall the ram memory modules.
Computer unplugged from power, press the Power On button in.
Hold the button in for a count of Five seconds.
(Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory settings.
Plug the computer back into power.
WAIT 1 minute, then turn the computer on.
I await your findings, and answers to my questions.
Jun 04, 2010 | Computers & Internet
Ram SUpport
According to the specs of this motherboard, it only supports a maximum of 256 MB of SDRAM. So, it definitely does not support 1 GB DDR2 memory modules.
Jul 11, 2009 | IBM (09N5424) Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I have motherboard ibm rev 1.6 and
The simple answer is NO, you will need to upgrade to a whole new Motherboard and of course the cost of this is essentially the same as building a whole new PC so you may as well look into a whole new system.
Jan 20, 2009 | Computers & Internet
PC work slowly when opening a program
Max. 8 GB, DDR2 800/667/533 (any one of these 3 types)
Dec 10, 2008 | ASUS P5BVMSE Motherboards
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
IBM (09N5424) Motherboard Logo
8,203 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
