Question about Samsung Televison & Video
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds then flashes for about 30 secs then goes off,if you turn the power button off & back on it dose the same,if you leave the power button on it dose not reset its self.I have checked the fuse in the plug & the glass one just inside the of the back to theright of center
    Problem Solver:
  • 4 Answers
Check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
Posted on Jan 21, 2009
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
I have Samsung 46" rear projector TV the TV just went blank
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Samsung tv SP42W4HB fails t power on!Please help!
Typically a convergence amp fails and causes the shutdown. There are two to handle the job so when one goes both should be replaced. This failure may also damage associated fuses and resistors.
Nov 06, 2008 | Televison & Video
Blinking Check Fan Light Message
sounds like the unit is truly unhappy, eh? the power board is most likely down de tubes, mon
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Sony VPL-ES1 projector
Hi Max
Is there any power on the unit at all ?
i.e. Does the LED's on the unit indicate that it is in stanby ?
If it isn't then it could just be a fuse that has gone on your Powersupply.
Apr 21, 2008 | Sony VPL-ES1 Multimedia Projector
Samsung sp42w4hb rear projector tv
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
Samsung projection TV intermittent shut-down problem
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC. JOE TV
Oct 04, 2007 | Samsung - Projection TV replacement lamp...
Televison & Video Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
