Question about EnGenius EAP-3660 802.11b/g Wireless Access Point
Problem loging into the web page of EnGenius EAP-3660 Access Point
I have EnGenius Access Point which as been used as a repeater i have Engenius but now i want to change it back to work as Access Point, my problem is when i tried loging into the device from the web page using 192.168.1.1 which is the default IP but it didnt open the login page to the device after pressing the reset button on the device
    New Friend:
I thought the default IP was 192.168.0.1. That is where mine went when I pressed the reset button.
Posted on Jan 13, 2013
manoline
  • 52 Answers
SOURCE: how do i reset my Engenius EOC-3220
This might be helpful
http://www.fixya.com/support/t629167-getting_setup_pages
Posted on Nov 07, 2008
  • 351 Answers
SOURCE: resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Posted on Dec 03, 2008
Macs R We
  • 481 Answers
SOURCE: restoring engenius EOC 8610 to factory default
Resetting the older beige Engenius radios requires a screwdriver and a USB-to-serial cable. You must unscrew the small plate at the bottom, which covers a serial connector. Plug the serial cable into it and then into your computer. Follow these instructions to perform the reset:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Posted on Oct 28, 2009
Macs R We
  • 481 Answers
SOURCE: cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
Macs R We
  • 481 Answers
SOURCE: engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
Posted on May 17, 2010
WiFi disconnects
the problem with your AP , change it
Mar 14, 2014 | EnGenius EAP-3660 802.11b/g Wireless...
Lost password,after reset (pressing for 5 second), admin/admin failed to log . Pl advice.
Some engenius wireless access points do not have a username password configured by default, so try it with the username and password fields both blank.
Sometimes, I have tried to reset the password on a wireless access point, and later figured out that I had failed to successfully reset the device. Make sure that the device is plugged in while you hold down the reset button. Hold down the reset button for 30 seconds instead of 5.
May 08, 2011 | EnGenius EAP-3660 802.11b/g Wireless...
Engenius eap-3660 access points channels chashing.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
EnGenius EAP-3660 802.11b/g Wireless Access Point Logo
333 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
