Question about Olympus WS-100 Digital Voice Recorder
CHECK The voice recorder flashes CHECK and then the time. How do I get past this, so that I can record something else or playback a previous recording?
  • Jamesam Dec 05, 2007
    I have a similar problem, but I can't get *any* response. I see the "CHECK" (and hear a double-beep), and "SEE YOU" messages at start-up and shutdown. On the display, I see Folder B, a full battery icon, HQ, a microphone with HI, "00", and "00:00". None of the buttons seem to do anything, with the exception of ON/OFF and Hold. I've tried holding them, and no difference. I tried removing the battery, replacing the battery, holding buttons when installing the battery. I plugged it into my PC, and was able to see everything, removed the data files. Didn't change anything.
    I think it might be busted. It worked, and now it doesn't.
Thanks, Noggin, for pointing me in the right direction. The HOLD switch was set to HOLD. Once I switched it off, I was able to access my previous recordings and can make a new recording.
Posted on Jul 02, 2007
  • 944 Answers
Here is the link to the user manual; http://www.olympusamerica.com/files/WS100200Sman.pdf depending how important the previous recordings are, formatting the recorder (page 2) may be the best option - can you still access the files if the recorder is connected to a PC?, in which case save the files you want and try the format. If this doesn't help, please ask again :)
  • Anonymous Jul 02, 2007
    welcome :)
SOURCE:
WHY WONT IT RECORD OR REPLAY - THE MACHINE RECORDS TIME BUT THERE IS NO SOUND
try plugging in an external microphone, if that works and it records then the microphone element in your machine is bad or a wire has broken off of the microphone
Apr 13, 2015 | Philips Pocket Memo LFH9370 Handheld...
When recording and on playback, there is a very loud hum over the recording and voice is barely audible.
There is an internal switch for record/playback. This commonly fails causing this issue. It will need to be replaced.
Aug 19, 2011 | Philips Pocket Memo 381 Handheld Cassette...
I miss a few words...how do I back it up to get to that spot. When I try it...it goes all the way to the beginning. Very frustrating. Thank You.
Hello I think what you want is to over record on a top of the previous dictation, but this recorder does not work that way example: let say that you are counting 12345678910 and you want to correct and add ACBD between 5 6 to listen back 12345ABCD678910. This recorder don't work that way, the only feature that this unit have is add or insert to the end, on the file that you are listen. During playback press REC for more than 1 second the record indicator appears and "ADD" will flash for 3 seconds in the display window the indicator will turn red and the new recording will be added at the end to the current message.
I really recommend if you want to used a Digital Recorder like the old style analog recorder with a slide switch this unit is really easy to operate and all the features that anyone needs, I think the price is not bad, is really a professional digital recorder http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 19, 2011 | Sony ICDB600 Digital Voice Recorder
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
Jun 08, 2009 | Sony ICDP620 Digital Voice Recorder
Sony ECM-HW1 Professional Microphone
it might voice automated and the flash could be pause until unpaused some recording devices have a constant light and some have a flashing light when recording check to see if pause is enabled
Apr 27, 2008 | Audio Players & Recorders
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
Mar 31, 2008 | Olympus DS-40 Digital Voice Recorder
Skipping during the recording process
"trying to record during playback"?... You can't record while playbacking in stereo mode, only in multitrack mode.
Mar 08, 2008 | Zoom H4 Handy Recorder
Olympus WS-100 Digital Voice Recorder Logo
104 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
