Question about Dimplex Compact Electric Flame Stove Heater
Manual for electralog model 6901050600 - Dimplex Compact Electric Flame Stove Heater
Heat stops working after a few minutes
A manufacture name and what type of heater would be helpful.
Mar 30, 2014 | Electralog Home
Dimplex electralog is making an intermittent squeaking sound?
When it is switched off try spraying WD40 around end of spindles. Try heater again after about an hour.
Nov 30, 2013 | Dimplex Compact Electric Flame Stove...
I have a electralog fireplace model #cs 3311. It doesn't stay on very long. Even if i turn the thermostat up it doesn't turn on
It's probably the Temperature Cut Off Switch. It turns the heater off if it's overheating. To reset the switch turn the Main On/Off Switch to OFF . Wait 5 minutes and turn it back ON.
If you need to continuously reset the heater, unplug the unit and call Dimplex North
America Limited at 1-800-668-6663.
Hope this helped to solve your problem.
Mar 08, 2011 | Heating & Cooling
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
Flame on electralog stove not working stove is still working
Rich's answer works for the heater problem, but not the light. My unit's heater quit working and I noticed the vents were clogged with dust. I vaccumed the front and back vents out with the unit unplugged and this fixed that problem. But the light/fire burn out is a different problem. I suspect it is burnt out bulbs, as I have had this unit for multiple years.
Sep 11, 2010 | Dimplex Compact Electric Flame Stove...
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
I have a dimplex electralog model cs4416 and it is still heating but will not blow the heat out what can i do
I beleive the heater and fan switch are a dual unit. Mine has a AUOne ST 360. I pulled the part outand it the copper is very pitted and corroded. The problem I have found is that this switch is made in China and I have had no luck finding a US distributor.Electralog/Dimplex... has an toll free number but it is hard to get through. 1-888-346-7539. If anyone gets through on thier problem, please ask about price and delivery and where to order. I would love to see this posted.
Nov 22, 2008 | Heating & Cooling
Dimplex Compact Electric Flame Stove Heater Logo
183 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
