Question about Home
How do you stop things from slipping around on the cutting board when you are using a sharp knife?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
The hand that you are not using to hold the knife is called your guiding hand. It holds the food and keeps it from slipping around on the board.
You should use something called a claw grip, where you use your free fingers to grip the food that needs to be cut whilst tucking them under so that they wont be in the firing line if the knife slips.
Posted on Jan 10, 2013
FILLET Knife sharpening
I use silicone carbide sharping stones , these keep things sharp and cool , as you never want to heat the blade while sharping them, takes the edge right off them (heat)
Jan 30, 2016 | Garden
One of my co-workers laminated several things that ended up rolling back in on itself inside the machine.
I had exactly the same and it is due to not using a document carrier. Some machines need one, some don't. The ones that don't have Teflon coated rollers.
You have to take the machine apart and use a small sharp knife to split the document. Put the knife blade outwards so it doesn't cut into the roller. I used a butcher's boning knife because we have a commercial kitchen.
Jan 29, 2016 | Gbc HeatSeal Ultima 65 Laminating System
Stihl pole saw model HT75--Was cutting a limb and the chain stopped cutting--What is the problem?
Could be a few things.
1. Clutch slipping at engine end.
2. Drive shafts have become detached from drive or broken.
3. Clutch behind the drive sprocket on the cutting head may need tightening.
4. Chain too sharp/aggressive and is trying to cut too much and the stopping the chain.
5. Chain too tight.
Nov 11, 2015 | Stihl Garden
How to stop crying when you cut onion?
Hello.
You can just dunk the onions in Iced water for 30 seconds, or even boiling water, this will change the texture of the onion. Next thing to do is use a very sharp knife, start out by cutting the roof, it'll eventually release the gas. That's it.
Jul 22, 2014 | Odm Link SDD99B3 5 Watch for Women
Do I need to sharpen my knife?
Every time you use your knife, the edge will become slightly less sharp, and you are more likely to injure yourself with a dull blade than a sharp one, as they can slip while you are working. Make sure you buy good knife-sharpening steel and use it each time before cutting with your knife it will also prolong your knife.
Jul 25, 2012 | Camping, Backpacking & Hiking
How do I remove the battery cover on my Samsung E1120. It has a part black part silver back and I can't move any of it. Thanks
The back cover is in one piece. Insert a sharp blade at the black end in the fine joint between the back cover and the body of the phone and carefully prise them apart. Once you have the blade in work around the whole of the joint until the back cover is loose.
Be careful you don't let the knife slip and cut yourself!
Jan 28, 2011 | Cell Phones
When I feed the board in it stops then starts again. ever four inches. Leave a little snip in board. I've replaced the belt an the chains on the in feed and out feed still have this problem.
Couple of things to check:
1. Are your knives sharp? Dull knives will cut not fast enough to keep up with the rollers.
2. What is the depth of cut? Dewalt's planers cannot plane a board to excessive depths.
3. Are you rollers clean? Dirt, pitch or possibly grease could affect your feed rate.
4. The belt/chain for your rollers engaged or are they slipping? Open up the planer and check for wear or possibly broken belt/chain.
Snipe is usally caused by improper support while exiting the planer. Use outfeed rollers set to the correct height. Also chek that you outfeed bed is aligned with the bed of the planer.
Hope that helps,
Dec 20, 2010 | Dewalt Tools & Hardware - Others
How do i replace the light switch in my RTD1900D?
I am guessing that you mean the door switch, so: remove power then using a sharp knife slip it under the switch flange and, pry up gently then: do the same thing on the other side and all around the switch until it comes out; remove the spade wire connectors
Jul 22, 2010 | Maytag Refrigerators
How do I take an iTrip apart?
Cut around the seam with a sharp xacto knife. It will open.
the crystal had come loose. I glued and sildered it back on. I'm back in usiness.
Jan 05, 2010 | Griffin Technology Griffin iTrip AutoPilot...
1 cut through the mower cable. Is the mower repairable?
Sure, it's easy. All you need is a sharp knife and some electrical tape.
1. Cut the ends off square
2. Expose the copper wires about 1/2"
3. Twist the same color wires together
4. Put tape around each end separately
5. Put lots of tape tightly around the whole thing
Oct 31, 2009 | Garden
Home Logo
366 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
