Question about AZiO Levetron Clicker Mechanical Keyboard KB528U
Levetron clicker keyboard keys not working - AZiO Levetron Clicker Mechanical Keyboard KB528U
Can't click on right
Hi!
That depends on the quality of the mouse that your using.
Cleaning/ opening the mouse will not work at all.
The quality of the mouse.
Jan 25, 2014 | Kensington Expert Mouse Trackball
The mouse button doesnt always work
Hi!
There is a problem on your clicker and maybe your mouse had work for a long time. It calls for replacement.
Jan 22, 2014 | Samsung R719 keyboard - R719 laptop...
Laser no longer working
I have a feeling that the wire has a break in it it should be an easy fix Check for continuity with a multimeter.
Nov 28, 2013 | AZiO Levetron Laser Gaming Mouse GM-2000 /...
Wont connect up to my computer and other mouses work in the usb slot so its my mouse and when i wiggle the usb it sometimes will connect and work.
Throw the mouse in the trash and replace it with a new USB laser mouse. They are cheap, not worth fixing.
If you are dead set on fixing it, you'll need a new USB plug. You can clip it off a broken something, or you can purchase the plug itself. Match up the wires and you're golden. I would just replace it myself. Good luck.
Sep 08, 2013 | AZiO Levetron GM533U USB 5000dpi...
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
Feb 26, 2013 | Computers & Internet
Murgee Auto Mouse Clicker Registration key please
I'd recommend that you use Asoftech auto clicker that I always use.
here the auto clicker download url
http://www.asoftech.com/auto-clicker-download.html
Feb 08, 2012 | MurGee Auto Clicker MurGee
Mouse clicker does not always work seems to be selective on what it will allow you to do.
It could be dirty, sticking, or just worn out. Get a can of compressed air and try to clean the spaces between the "clicker".
Hank
Aug 04, 2009 | IBM 06P4069 Mouse
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
Jan 31, 2009 | Compaq Presario Notebook
Left clicker doesn't work on my hp optical mouse
Sorry to say it's most likely a failed switch on the mouse. You will have to replace it. Try a hard-wired mouse first if you can to confirm.
Dec 09, 2008 | HP Wireless Optical Mouse
AZiO Levetron Clicker Mechanical Keyboard KB528U Logo
57 people viewed this question
Top AZiO Computers & Internet Experts
David Payne
David Payne
Are you an AZiO Computer and Internet Expert? Answer questions, earn points and help others
