Spongebob chainsaw juggler code - Televison & Video
Can you make your own juggling clubs?
Check out this tutorial on Juggler Org that shows you how to make your own juggling clubs. It's not that simple, so you have to love DIY, and if not you might find it just easier to buy, but if you love a challenge you might enjoy this project.
http://www.juggler.org/diy/clubs.shtml
Feb 25, 2013 | Crafts & Hobbies
Universal remote code for spongebob tv
I doubt you will find any that work---no one so far has--Google for a replacement remote other than the universal.
Dec 03, 2012 | Emerson SpongeBob SquarePants TV
Code to spongebob squarepants 13'' located at
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Try these codes.
Apr 17, 2012 | Emerson SpongeBob SquarePants TV
Where can i find a remote control for a spongebob television?
Try website like Remotes.com to buy the exact same remote.Don't tries universal remote on this tv,there no codes for it,because these tvs was limited production tv for Disney corporation.
Sep 04, 2010 | Emerson SpongeBob SquarePants TV
Need the code to spongebob tv set to set up my remote control
The original code is 1111. If you've forgotten the code that you've put in you can use 9922. Good luck!
Feb 21, 2010 | Emerson SpongeBob SquarePants TV
Scratchy and skipping sound inspiron b130
The computer may has a program that takes control of the processor at this time. You may view most of the processes happening on the computer by opening up the "Task Manager". You may access this by "Right Clicking" the "Taskbar" or "Ctrl" + "Alt" + "Delete", and go to the "Processes" tab. Next you will want to click on the "CPU" line to view what processes are using the CPU the most. You may have to click on the button "Show Processes from All Users" to see all of them. The most likely possibility is the computer is compromised by a spy of some sort. I have seen this from Social Networking sites. I always recommend backing up all your important files however you desire to back them up. IF this process hog cannot be found it also could be a Memory hog as well. If the memory used goes near the Physical Memory available the computer will reduce the other processes to keep the computer running. All the processes running are like a Juggler, the more processes running with little Physical Memory is like the Juggler Juggling all those "Balls" within a small room, somewhere the juggler is going to drop a ball, in this case it may be the sound from the computer. In your case I would hope adding memory would be the best remedy for this situation.
Sep 17, 2009 | Dell Inspiron B130 Notebook
Codes
Emmeron code 0623 worked for me!
Jan 02, 2008 | Emerson SpongeBob SquarePants TV
Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Apr 17, 2007 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
