Question about Clarke Tools & Hardware - Others
My Clarke American Sanders CA 12 will run for about 10 minutes but then shuts off, what could the problem be?
Ez 8 sanding machine will not start
Hi there
did it smoke or smell funny or did it just stop
either way check the drive/run capacitor that is usually
what will stop them from starting/running
Jul 15, 2014 | Clarke 07058A EZ-8 Floor Sander Expandable...
Clarke sander
Once we plugged it into an outlet with a trip switch it worked.
Jul 28, 2013 | Tools & Hardware - Others
Clarke belt sander runs in reverse
sounds like a wiring issue with in the machine?
Sep 10, 2012 | Tools & Hardware - Others
I have a Clarke Model 504 floor drum sander. where can i find paper for this?
I would recomment trying a local rental yard. they usually have the paper and machines for rent. If not let me know and I will do some more research with Clarke, give me your general area with zip code and I will try and find a local source.
Jan 09, 2011 | Sander Industrial Original Clarke Floor...
My belt sander is eating away to much on the left side and it is also leaving cut lines on the floor.. does anyone have a solution or a guide to how to fix this problem? my floor sander is a "Clarke...
I would first look at the discs for uneven wear but if you want and I would recommend going to "Clarkeamericansander.com" they hae service and support and technical services who can better serve you. they also have tool free numbers listed for assistance. where I work I have called them are they are really there to help. Good Luck
Sep 23, 2010 | Clarke Floor Sander Floor Sander Orbital...
I have a Clarke C-5 Edger and need parts
what kind of parts are you looking for. I had Clarke American Sanders send me a copy of the breakdown and I will try and help you.
Nov 15, 2009 | Clarke Tools & Hardware - Others
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
I own i 20 gal. clarke abrasive blaster. My problem is that i can only blast for about 30 seconds and then have to wait almost 2 minutes for the pressure to build back up
Sounds like your compressor doesn't have the cfm to keep up with the blaster. Blasters use a lot of air. The cfm of your compressor should match or exceed the cfm of the baster. Try a bigger compressor.
Good Luck!
Aug 20, 2009 | Clarke Power Products Clarke 10 Gal....
Tools & Hardware - Others Logo
55 people viewed this question
Top Clarke Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Outback Jack
Outback Jack
Are you a Clarke Tool and Hardware - Other Expert? Answer questions, earn points and help others
