Question about Tomy Toys
Battery install tony thamas 1992 - Tomy Toys
Short battery life
you can get a new battery installed for next to nothing!
Tony
iRefresh, iPod repair service
Feb 25, 2013 | Apple iPhone 4 Black Smartphone
Tony Hawk ride board will not power up. New batteries have been installed.
you should take it to walmart to exchange for a new one.
it should work even if you have no proof you bought it there.
let me know.
doug.
http://www.fun-4me.com/tony-hawk/ Tony Hawk Ride and Shred Forums
Jun 23, 2011 | Video Game Consoles & Games
I think this is an SBA 1600. How do you open the case to replace the batteries?
This unit utilizes 3 AAA batteries. The battery cover slides forwards and out. Then install new batteries.
Regards, Tony
Apr 12, 2011 | Audio Players & Recorders
Cannot calibrate Tony Hawk Shred for Wii
I had the same problem. I solved it and got the board to calibrate immediately when I replaced the brand new batteries with used batteries. Brand new batteries apparently make the lasers very sensitive. You have less sensitive sensors with the used batteries. I just took some AA's out of my cable remotes. The game is awesome once you get it calibrated. I felt your pain for an hour or so.
Dec 25, 2010 | Activision Tony Hawk Ride for Nintendo Wii
Will not charge
I have the viper rpn 7752v remote. I was away for a month and the remote completely died. I plugged it into the usb and nothing would happen. I called the installer and he told me a savvy trick. After plugging it into the usb, press the function button. Repeat this several times before it actually turns on. Repeated attempts eventually worked. He said even the manufacture doesn't know why this works. If you still need help you can email me and I'll refer you to a good installer. Tony@bostoninvestments.com. Tony Madan
Dec 10, 2010 | 7752V Replacement Transmitter Supercode...
Hi i have a 1992 dodge ramcharger with a 318 engine.runs for 10 to 15 minutes then dies,then will crank but not start,not getting spark.i have replaced fuel pump,fuel filter,fuel lines,ignition coil,pick...
Look for some electrical or fuel related heat affected problem ... Something stops working when the car gets to operating temperature. Beyond that, I can't be more specific, Tony. Good luck ... When you find it ... post your answer please.
Thanks for using FixYa.com
Nov 05, 2010 | Dodge Ramcharger Cars & Trucks
Starter install 1992 buick roadmaster how to remove
Do you mean the starter-motor removal?
Disconnect the battery. Disconnect the red/positive battery cable from the starter. Trace the red/positive cable to where it ends (that's the starter), disconnect it from the solenoid. Use applicable socket wrench/flat-wrench to unbolt/remove the starter-motor. Installation is reverse of removal.
Nov 10, 2009 | 1992 Buick Roadmaster
WHAT IS THE TRICK TO REPLACING A BATTERY ON A 1992 LUMINA
  • Loosen the battery negative terminal clamp.
  • Use a terminal clamp puller to remove the negative cable.
  • Loosen the battery positive terminal clamp.
  • Use a terminal clamp puller to remove the positive clamp.
  • Remove the battery hold-down hardware and any heat shields.
  • Remove the battery from the tray.
  • Install the new battery into the tray.
  • Also install the hold-down hardware.
  • Install the positive battery cable.
  • Then install the negative cable.
  • When installing a battery, be careful to observe the correct polarity. Reversing the cables destroys the diodes. Proper polarity must also be observed when connecting a booster battery, positive to positive and negative to ground.
Art courtesy of Delmar - Thomson Learning.
  • Coat the terminals with corrosion preventative spray, then check the job by starting the car.
Jan 09, 2009 | 1992 Chevrolet Lumina
Toys Logo
Top Tomy Toys Experts
Jennifer Rock
Jennifer Rock
Colin Stickland
Colin Stickland
ray gallant
Are you a Tomy Toy Expert? Answer questions, earn points and help others
